06-26-2019, 10:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | frp remove error why? Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
06-26-2019, 10:37 | #3 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | Card found : 69F34682 , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v123080 Ok! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00002001 : DA SEND ERROR! ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE! INFO : PRELOADER Level : Connect device in BROM mode! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM20) MODE : BOOTROM PORT : 20 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100513832334D42001109CE1886F5 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 510001154D33323809110042F58618CE NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DA : Failed to configure DA! ERROR : 00000BC4 : DEVICE NOT FOUND Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
06-26-2019, 13:00 | #5 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: @India
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | Quote:
06-26-2019, 13:12 | #7 (permalink) | |
No Life Poster Join Date: Oct 2012 Location: IRELAND
Member: 1824733 Status: Offline Thanks Meter: 2,659 | Quote:
U can use factory frp tool and buy cheap frp service or instant and do it easy way frp remove | |
06-26-2019, 13:22 | #8 (permalink) | |
No Life Poster Join Date: Jul 2010 Location: cameroon
Member: 1356561 Status: Offline Thanks Meter: 433 | Quote:
06-26-2019, 13:50 | #9 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
06-26-2019, 15:36 | #11 (permalink) |
Member: 1824733 Status: Offline Thanks Meter: 2,659 | Thx for your blame my post !! U can download huawei factory frp tool working correct adb cmd and all install it when done open adb tool connect huawei phone fastboot mode add correct command press enter read correct imei and serial number whe that done and you have frp key open factory frp tool and have two option remove frp fully or clear frp so all easy way. I cannot help or post you here any more thx for i can help you my stupid advise ...... |
