10-29-2008, 23:13 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
10-30-2008, 00:50 | #8 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Quote:
10-30-2008, 01:28 | #10 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | my flash is: ver. sw1: MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16.BIN ver. sw2: MAUI.05C.W06.16, 69F99C39 I would like to know if you want my backup? I would like to know what the file compatible with my unit because it was my turn on and off |
10-30-2008, 09:27 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! please post reading flash error log. you must start from reading full flash, continue with format FFS complete, restore IMEI. only after this worth to try flashing |
10-31-2008, 21:01 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! check if both IMEIs match to IMEI sticker under battery. for some models this is important for correct work Last edited by InfinityHelp; 10-31-2008 at 21:07. |
Crashed Bootneuter, contact apple msg – 1011 error | ckinsella | iPhone 4 / iPhone 4S | 14 | 10-21-2010 08:44 |
Unknown Error Occurred 1011 | 07heaven | iPhone 2 / iPhone 3G / iPhone 3GS | 15 | 01-05-2009 12:01 |
SEARCHING: Older Nokia Phones: Talkman, c6, 1011, pt10 & 11 2190, ringo 2 & 3, 5165. | CyberoptiK | Wanted Products | 0 | 11-10-2008 06:16 |
nokia 1011 trouble :-( | gb1967 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-07-2004 21:39 |
Old Nokia 1011 need to unlock | Corban | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-22-2002 23:45 |
