05-05-2010, 06:05 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | G-TIDE G838 Firmware Needed i am needed G-TIDE G838 firmware or full backup file. HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_108 |
05-05-2010, 20:02 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! are you sure that you have to flash it? maybe problem could be solved by format FFS/IMEI restore? we dont have exactly same firmware in our collection, but you can try similar one after you make fullbackup: flashfiles/ChineseMiracle/_MT6225/HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_110__G-Tide-G838_16m_En_Ru_Fr_Es_Id_Tr_Farsi_Pt_Ar.B0M.bin |
05-06-2010, 05:05 | #4 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | great ...........after flashing with your said file my set is power on and working.............thanks infinity team..... COM6 [VCP1] selected module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware HEXING25_GEMINI_PCB01_GPRS_MT6225_S00[1].MAUI_GEMINI_W08_12_110__G-Tide-G838_16m_En_Ru_Fr_Es_Id_Tr_Farsi_Pt_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1003:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: E:\InfinityBox\ChineseMiracle\backup_security\id.8 21519E4.[MTK25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_06 .BIN_50894D5C].rpl rom info detection finished device-id: 821519E4 rom info ver: 04 sw version: MTK25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_06 .BIN project-id: MAUI.06B.W07.12.06, 5C4D8950 code offset: 00000000 ffs offset/size [01]: 00600000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00600000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00E00000 Detected ffs/eeprom address is non-standard: 00E00000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: MTK25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_06 __ffs... file saved: E:\InfinityBox\ChineseMiracle\MTK25_06B_PCB01_GPRS _MT6225_S00.MAUI_06B_W07_12_06__ffs_20100505-205130.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: E:\InfinityBox\ChineseMiracle\backup_security\MTK2 5_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_06__sy stem_log_821519E4_50894D5C_20100505-205137.B0X.bin Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: E:\InfinityBox\ChineseMiracle\backup_security\MTK2 5_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_06__sy stem_log_821519E4_50894D5C_20100505-210110.B0X.bin Finished, time used: 11 min 36 sec Remove/Install battery now ! |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
