05-10-2013, 23:10 | #1 (permalink) |
Banned Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks Meter: 899 | g7105 unlock DONE................. module v4.45 Device: _Autodetect MT6205-6239 NOR Checking data, wait... Operation: SP-unlock unlock method: read codes interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! BaseBand chip version: MT6253, E04 ECO version: DSP firmware version: 2000.00.00 DSP patch version: 1.0 S/W version: W5.1EG01V01.07 H/W board version: BYD53_10A_HW Melody version Melody V0.0 Version: W5.1EG01V01.07 detecting structure imei... done 136 byte(s) read imei #1: 867874002239911F0000 detecting structure simlock #1... error: detection failed (16 tries) detecting structure simlock #2... done 227 byte(s) read 188 byte(s) read lock[1] code: + 66564613 lock[2] code: + default lock[3] code: + 11112222 lock[4] code: - 33334444 lock[5] code: - 55556666 lock[6] code: + 77778888 lock[7] code: + 99990000 if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Shutdown... done Finished, time used: 3 min 18 sec Remove/Install battery now ! AK' |
