06-25-2018, 12:01 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Georgia
Member: 772384 Status: Offline Thanks Meter: 40 | General mobile 6 rom MT6737T__generalmobile__GM_6_d__GM6_d_sprout__7.0_ _SWW1616TG_0201_T5508? |
06-25-2018, 15:51 | #3 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! Enviado do meu SM-J100H através do Tapatalk |
06-25-2018, 17:04 | #5 (permalink) |
Member: 772384 Status: Offline Thanks Meter: 40 | phone was alive before ,I unlocked bootloader and flashed system file ,imei become null ,then i flashed with infinity cm2 backuped file factory firmware ,most probably I forgot to relock bootloader ,so phone became dead ..any advice? now I flash it with bachuped agayn but phone is dead? |
06-26-2018, 09:40 | #7 (permalink) |
Member: 772384 Status: Offline Thanks Meter: 40 | I found working phone ,read full flash and when I was trying to flash it it shows Card found : S/N : 264F9559 , v0136 Chinese Miracle II [MTK module] v 1.58 Load File FileVersion : MT6737 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : MT6737T__GENERALMOBILE__GM_6_d__GM6_d__GM6_d_sprou t__SWW1616TG_0201_T7324__Android_8.0.0.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 105 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D42315890CB0742EB269BE0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1X [eMMC] : FLASH_CID : 150100525831424D4207CB90E09B24EB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x5E19A14B7B5E14C61AA0CEE0CFAA9201 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : 6737 , TARGET ID : 6735 BBID missmatch! Stop killing phone!!! Select CORRECT file for that phone! Done! Elapsed: 00:00:12 Reconnect Power/Cable! Load File FileVersion : MT6737 Load File Ok Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : MT6737T__GENERALMOBILE__GM_6_d__GM6_d__GM6_d_sprou t__SWW1616TG_0201_T7324__Android_8.0.0.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 105 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D42315890CB0742EB269BE0 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1X [eMMC] : FLASH_CID : 150100525831424D4207CB90E09B24EB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x5E19A14B7B5E14C61AA0CEE0CFAA9201 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : 6737 , TARGET ID : 6735 BBID missmatch! Stop killing phone!!! Select CORRECT file for that phone! Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
