07-29-2010, 16:34 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: K.G.M Age: 50
Member: 751908 Status: Offline Thanks Meter: 186 | LG KG195 format ffs error module v3.52 Device: LG-KG195 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:A741:E5EC status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 29EA00F018E59F:29EA0000000000 flash: AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] type TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BIN project-id: 7S7332SA00-001, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] type TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 29EA00F018E59F:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 29EA00F018E59F:29EA0000000000 error: no any expected answer error: flash erase error: 00E00000 error: no any expected answer error: erase #E2 error: format ffs failed Finalization Fail Finished, time used: 1 min 12 sec Remove/Install battery now ! |
07-29-2010, 21:53 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | I think that this phone can not power on and has damaged hardware. I suggest you open phone and check it's hardware, f.e. water inside, reball flash and/or CPU chip etc. |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
