02-25-2016, 19:16 | #1 (permalink) |
Freak Poster Join Date: Dec 2010 Location: India
Member: 1471997 Status: Offline Thanks Meter: 22 | Getting error in reading firmware... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 345 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 002C00440044004B00A9000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Read Flash [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 54 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 002C00440044004B00A9000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x004E , [MICRON] MT29F32G08CBADB [NAND] : FLASH_DIE : 002C 0044 0044 004B 00A9 0000 0000 [NAND] : FLASH_LEN : 0x100000000 [NAND] : FLASH_EXT : 2000/0100/00/ DEV RID : 1D9F981AFCB91F1F0A6E03CCCA1AEA95 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Error while reading initial info! First make sure about "ReadInfo" passed fully! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! |
02-26-2016, 07:33 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Check Nand Extra option (Infront of Read Firmware button) and then read factory firmware. Or read info successfully first by changing Nand Init mode from Settings-SP:Other-Nand Init Mode. Br. Infinity Box Support Team. |
03-17-2017, 06:35 | #4 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: bangladesh Age: 34
Member: 1104393 Status: Offline Sonork: 100.1603062 .::RONY::.. Thanks Meter: 130 | yes i change Quote:
