09-14-2016, 10:51 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: @India
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | Getting Problem In Writing Permanent IMEI In Most Of Panasonic Models.. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D5332376C5D0042F1BBEDD2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D42005D6CD2EDA2F1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA8D4419A9A39494D9A6F3DE4AAACFB95 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! IMEI [00] : 358688000000158 IMEI [01] : 358688000000158 IMEI [02] : 358688000000158 IMEI [03] : 358688000000158 Set IMEI [00] : 3533660xxxxxxxxx Set IMEI [01] : 3533660xxxxxxxxx Prepare finished. Security check required! Wait for phone... Phone found! [ 20 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just re-insert cable) on this step Reconnect Power/Cable! |
