10-07-2010, 03:09 | #1 (permalink) |
Insane Poster Join Date: Jan 2009 Location: India
Member: 943633 Status: Offline Thanks Meter: 10 | Pinfinder problem |
The Following User Says Thank You to srinivasacharlu For This Useful Post: |
10-07-2010, 21:12 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! sorry, i dont get: when you press "power" in pifninder software- does 5v is appearing on RJ45 power cable contacts? this is main rule for pinout search. Even more: phone should be powerable sourced from this cable |
10-09-2010, 07:34 | #5 (permalink) |
Junior Member Join Date: Apr 2008 Location: esmeraldas-ecuador
Member: 746431 Status: Offline Sonork: 404 Thanks Meter: 3 | helpme... COM5 [VCP0] selected module v3.20 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection disabled Action: read flash ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot Off chip: 0000:0000:0003 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 15 sec Remove/Install battery now ! thanks.. |
10-09-2010, 18:28 | #6 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Keep power button pressed longer, until program asks to release it | |
10-09-2010, 18:29 | #7 (permalink) | |
which search method you use? Fast or slow? try slow one. Also make sure that this phone is Mt62xx family and does keep Tx/Rx in system connector | |
10-11-2010, 06:38 | #8 (permalink) |
Major Poster Join Date: Dec 2006
Member: 410873 Status: Offline Thanks Meter: 3 | combo pinfinder Hallo boss, y'day buy combo pinfinder conn upgrade everything ok,but when i serch pinfinder detect pinout and conn shell run china interface ''power on mobile'' no response,where is the mistake,and also conn new handset its detect very deleay,so pl help how run the software ,i thing its my fault or box fault,at the same time when i conn spiderman its detect pinout very very fast and use u r combo box with spiderman interface its fine,so i confusedpl help,t u |
10-12-2010, 01:49 | #10 (permalink) |
Member: 943633 Status: Offline Thanks Meter: 10 | Hello sir thanks for your support But i could not find pin out here is the log: software version: 1.23 platform: MT: MT62xx (autodetect) cable type: 1x18 (L18A) mode: Slow Fast searching adapter at COM8 (115200)... too many retries adapter found, version: 4000 pins: 18, plain power/activation cycles: 1/7 power-off delay: 20 start Rx/Tx: 1/1 Loading platforms configuration... Initializing platforms... Press and HOLD phone Power button now ! detecting pins... error: boot initialization step #2 failed: A0 failed to detect pins time required: 134 sec Trying to Power-On... Power On ! The power voltage is varying from 0.8v to 2.9v never got 5v. |
10-13-2010, 03:44 | #11 (permalink) |
Member: 943633 Status: Offline Thanks Meter: 10 | hello sir I tried with v1.20 . then also pin out not detected. one of my friend is using old (blue) box which is super and with new i could not detect even one phone. Infinity team please help |
10-13-2010, 12:14 | #12 (permalink) | |
Temporary banned !! Join Date: Dec 2008 Location: On To Hot
Member: 935605 Status: Offline Sonork: 100.1601177 Thanks Meter: 78 | Quote:
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
