06-12-2022, 21:27 | #1 (permalink) |
Freak Poster Join Date: Jul 2014 Location: pakistan Age: 35
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | stuck in mtk port nokia G10 ta 1334 Operation : Memory Tool Init [ v2.32 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 6AC86591CE47C5FA26F74D59D05AE3B7 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4B3B27EB3B5AC90D98A325BB01DFC21EDB57E3422BB74670F0 766A597987F391 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : INFINITY EMI : SRC : PRELOADER_INFINITY_0 EMI : CNT : 0008 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 65646F4D204D4F5212D2000002400109 EMMC: VEN : UNKNOWN [0x65] : OEM : 111 : ID : 4D204D4F5212 EMMC: VEN : UNKNOWN [0x65] : M MOR EMMC: SNN : 576 ( 0x00000240) , MF : 0/2014 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00020000 [ 128.00 KB ] USER : 0x75700000 [ 1.83 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 682D07ED499DD73E6AAF077791BB6A2B DA : USB : HIGH-SPEED Boot done! Warning! Not found any mount point! If it blank IC - init GPT first! Set default path : C:\InfinityBox\CM2MT2\phdata\ |
06-12-2022, 21:31 | #2 (permalink) |
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | Operation : Write Flash [ v2.34 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Disabled SData Backup : Enabled Safe UserData : Disabled Flash Format : Disabled Files :1 [FL] : Set : userdata.img [FL] : Total size : 0x00198154 [ 1.59 MB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM8) MODE : BOOTROM PORT : 8 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Cervino TYPE : MODERN [RAPHAEL] BROM : MEID : 6AC86591CE47C5FA26F74D59D05AE3B7 BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM BROM : SOCID : 4B3B27EB3B5AC90D98A325BB01DFC21EDB57E3422BB74670F0 766A597987F391 BROM : SLA : Local Auth BROM : SLA : Starting Auth BROM : SLA : Auth Passed! BROM : SEC : 0x000000E0 AGENT : 0_base : BASE_v2112 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMMC: CID : 65646F4D204D4F5212D2000002400109 EMMC: VEN : UNKNOWN [0x65] : OEM : 111 : ID : 4D204D4F5212 : PRV : 0xD2 EMMC: VEN : UNKNOWN [0x65] : M MOR EMMC: SNN : 576 ( 0x00000240 ) , MF : 0/2014 EMI : DEV : MT6765 EMI : SRC : preloader_t99652aa1.bin EMI : CNT : 0004 EMI : [00] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 512.00 MB ] EMI : [01] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : [02] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ] EMI : [03] : DRAM : LP_DDR4 : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x0003A000 [ 232.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: CID : 65646F4D204D4F5212D2000002400109 EMMC: VEN : UNKNOWN [0x65] : OEM : 111 : ID : 4D204D4F5212 : PRV : 0xD2 EMMC: VEN : UNKNOWN [0x65] : M MOR EMMC: SNN : 576 ( 0x00000240 ) , MF : 0/2014 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00020000 [ 128.00 KB ] USER : 0x75700000 [ 1.83 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 682D07ED499DD73E6AAF077791BB6A2B DA : USB : HIGH-SPEED Boot done! [FL] : Pre-Flash backup [FL] : Pre-Flash backup passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000001688000 Erase : 0x0000000003688000 : 0x000000000769A000 Erase : 0x000000000C000000 : 0x0000000000800000 Erase : 0x000000000F800000 : 0x0000000000200000 Erase : 0x000000000FD00000 : 0x0000000000080000 Erase : 0x0000000013D80000 : 0x0000000000280000 Erase : 0x000000001E000000 : 0x0000000004000000 Erase : 0x0000000024500000 : 0x0000000000600000 Erase : 0x0000000032000000 : 0x0000000004000000 Erase : 0x0000000038500000 : 0x0000000000600000 Erase : 0x00000001C0800000 : 0x00000000C0000000 ERR : 0xC004000B ERR : EXCEED AVALIABLE RANGE ERR : 0x00000000|0x00000000 [DEBUG] : ERASE_BREAK , Skip erase [FL] : RePartition ERR : 0x00000000 ERR : OK ERR : 0x00000000|0x00000000 [DEBUG] : REPARTITION_BREAK , Skip repartition [FL] : Flashing now ... Write : USERDATA FAIL : ERROR SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
06-12-2022, 21:40 | #3 (permalink) |
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | phone had a password on i did memoery tool and erase user data like always after now phone stuck in mtk port cant flash and cant even read memory tool now |
06-13-2022, 01:04 | #5 (permalink) |
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | |
