Gigaset GS170 MT6735 DA req " Hi all as i mentioned if any one have this DA file plz share it here cm2 log Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! with volume pressed cm2 log Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333645B8B30342EB2596AC Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! --- thnx |
Wait for phone... Phone found! [ 45 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145468E0D4213BCF0AA Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! the same prob here:( |
2 ways 1. test DA_SWSEC_CRYPTO20 and DA_SWSEC from normal flash tool connect phone without holding keys 2.load frimware and connect phone with holding keys do you operation |
thnx but, it won't work , without even trying . i think the device belongs to Lava z285 board |
Hint right now : 150100514531334D42 MMX Q421, ZTE Blade V0720 If not find fw ( to select as base for EMI with 2 vol keys ) - will upload preloader tomorrow. |
@JayDi . i have ZTE blade v7 lite ( v0720 ) info PRELOADER version: MTK_BLOADER_INFO_v20 name: preloader_ztexa6735m_35u_m.bin CPU: MT6752 CUSTOM NAME: CUST Flash style: EMMC Flash definitions in preloader: 7 [1]Type: MCP(eMMC+DDR3) CID: 150100513331334D42 [2]Type: MCP(eMMC+DDR3) CID: 150100464E31324D42 [3]Type: MCP(eMMC+DDR3) CID: 150100523331424142 [4]Type: MCP(eMMC+DDR3) CID: 150100514531334D42 [5]Type: MCP(eMMC+DDR3) CID: 150100464E58324D42 [6]Type: MCP(eMMC+DDR3) CID: 90014A484147326505 [7]Type: MCP(eMMC+DDR3) CID: 450100444634303136 load adress: 0x200d00 PRELOADER END Android Info Build ID: MRA58K Display ID: ZTE_BLADE_V0720_CEL_MY_B01 Version: 6.0 Build Date: Fri Nov 18 12:01:33 CST 2016 Model: ZTE BLADE V0720 Brand: ZTE Device: ZTE_BLADE_V0720 Manufacturer: ZTE Mediatek Version Release: ZTE_BLADE_V0720_CEL_MY_B01 Android Info END |
press stop botton select your operation that you want do connect phone with holding volume keys |
and here's the preloader preloader_ztexa6735m_35u_m |
@xx0o0xx1, instruction given in previous post by @sky73 already. |
JayDi bro meizu mt6755 DA.bin not sopt all box dongle only mrt sopt plzz help |
I just used the preloader.bin to reset GS170 frp locked. I could reset FRP with the preloader.bin using Octoplus frp tool. Platform: __GENERAL RESET FRP METHODS Selected model: MTK CUSTOM Selected Preloader: C:\Users\\Downloads\preloader_ztexa6735m_35u_m.bin Please, power phone OFF (press and hold "Vol+" or "Vol-" button) and connect USB cable. Searching for a phone. Please wait... Found phone on COM13 Detecting Chip Version... HW Chip: MT6737: 0335.0000 HW Version: 8A00.CB00.0000.0000 Connecting... Brom Version: 05 BootLoader Version: FE Sending auth... Searching Download Agent... Selected DA: MTK_AllInOne_DA_v3.3001.2018-11-07.23:57_458956, n.10 Sending Download Agent... DA sent successfully Initializing DA... Synchronizing with DA... NAND Flash: not installed eMMC Flash: .15010051.4531334D.420D99F4.C2028077 eMMC Flash: Samsung: QE13MB DA ver: 4.2.9B Initializing Memory Flash.. Sending BootLoader Info... Initialization successfully completed Sending loaders... Loader send successfuly. Reading Flash Info... EMMC rpmb size: 4 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 14910 Mb Internal RAM size: 128 Kb External RAM size: 2048 Mb Reading partition... Reading info... Brand: Gigaset Model: Gigaset GS170 Device: GS170 Platform: mt6737m Android version: 7.0 Display ID: GIG_GS170_S110 Searching for signatures... Resetting FRP lock.. FRP lock is successfully reseted! Backup saved as Gigaset_Gigaset GS170_12-04-2019_17-11-34.dump file Performed by 1.6.9.0 Software version. |
