09-05-2011, 17:33 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | gild v5..... show " shfting " then restart Code: COM10 [Serial2] selected module v3.96 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:211E:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #02 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #03 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #04 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #05 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #06 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #07 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 98009600000000:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.96, database date: 21.06.2011): GINWAVE23D_GEMINI_ULC_07B_PCB01_GPRS_MT6223_S00.V5_01_V1_0_007_101101.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: GINWAVE23D_GEMINI_ULC_07B_PCB01_GPRS_MT6223_S00.V5_01_V1_0_007_101101.BIN project-id: V5_01_V1_0_007_101101, 00000000 code offset: 00000000 ffs offset/size [01]: 00760000/000A0000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00760000 standard ffs/eeprom offset confirmed: 00760000 detecting ffs/eeprom size... ffs/eeprom size: 000A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00760000-007FFFFF firmware area: 00000000-0075FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GINWAVE23D_GEMINI_ULC_07B_PCB01_GPRS_MT6223_S00.V5_01_V1_0_007_101101__ffs... file saved: C:\InfinityBox\MModule\GINWAVE23D_GEMINI_ULC_07B_PCB01_GPRS_MT6223_S00.V5_01_V1_0_007_101101__ffs_20110905-220020.B0E.bin flash: 98009600000000:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98009600000000:2BEA0000000000 Finalization Done Finished, time used: 1 min 57 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
09-05-2011, 17:55 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make backup and flash your phone with following firmware: flashfiles/1MTK/_MT6223/8m/GINWAVE23D_GEMINI_ULC_07B_PCB01_GPRS_MT6223_S00.V5 _01_V1_0_008_101109_2010-11-09_8m_En_Fr_Id_Tr_Farsi_Ar_Hi.B0M.bin |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Some idea for 6150 V5.17???? | cIVIc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-24-1999 01:19 |
100% unlock1 for Nokia 6150 v5.17 ------,......... | cIVIc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 02:00 |
3210 v5,24 unlock wanted | shadow77 | Wanted Products | 0 | 10-23-1999 17:36 |
Troubles with 6150 v5.17 | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:26 |
