01-04-2016, 08:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Gionee m5 after frp remove its ask for security password. Pls look Code: Start at : [1/4/2016 / 1:01:28 PM] Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 47 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 520001154D423132D6C40642673CF2CC DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB12 [eMMC] : FLASH_CID : 150100523231424D4206C4D6CCF29267 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! HERE IS IMAGE Br Puneet5154 |
01-04-2016, 10:59 | #4 (permalink) |
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Hello , ISSUE SOLVED, m Enter 12345678 then massege come decryption unsuccefull and then i click on reset and handset result issue solved |
01-04-2016, 11:02 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Ah, it "Encryption" enabled. Nothing extra, enough just "Repair ExtData" or "Format FS + Repair" |
01-05-2016, 19:25 | #6 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
I Have Factory Firmware & NVRAM Read By "One Of The Most Lovable CM2". Operation : Check / Read Info [ v1.40 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 520001154D423132E3C406421731C6CC DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB12 [eMMC] : FLASH_CID : 150100523231424D4206C4E3CCC69217 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : GiONEE ProdName : M5 ProdModel : M5 Device : M5 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V1.8.9_GNBJ6735.66T.L1_P42 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P58_1_lwg_n EXTRA : LCD : Not info available :( LCD Res : 1280x720 TOUCH [0] : GT1XX CAM [0] : s5k3m2_mipi_raw CAM [1] : s5k3m2_ofilm_ojlbp02 CAM [2] : ov5670_mipi_raw CAM [3] : s5k5e2ya_mipi_raw MODEM : gnbj6753_65c_l1_lwg_dsds gnbj6753_65c_l1_c2k_svlte_om LOCALE : en_US hi_IN pa_IN gu_IN bn_IN kn_IN ml_IN mr_IN ta_IN te_IN Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Read Flash [ v1.40 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 520001154D423132E3C406421731C6CC DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB12 [eMMC] : FLASH_CID : 150100523231424D4206C4E3CCC69217 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : GiONEE ProdName : M5 ProdModel : M5 Device : M5 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V1.8.9_GNBJ6735.66T.L1_P42 MediaTek MT67xx [x64] : Normalize settings Ok [Read Ok] : preloader_gnbj6735_66t_l1.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735 / V1.1.2 / gnbj6735_66t_l1 / EMMC FW Size : 2914 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6735__GiONEE__M5__M5__5.1__ALPS.L1.MP3.V1.8.9_GNBJ6735.66T.L1_P42\ All done! Done! Elapsed: 00:08:31 Reconnect Power/Cable! Operation : Read NVRAM [ v1.40 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 520001154D423132E3C406421731C6CC DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB12 [eMMC] : FLASH_CID : 150100523231424D4206C4E3CCC69217 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P58_1_lwg_n Read Ok, MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V16_P58_1_lwg_n_eMMC.spnv saved Done! Elapsed: 00:00:21 Reconnect Power/Cable! | |
The Following User Says Thank You to MyGSM World For This Useful Post: |
01-06-2016, 07:34 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @mygsm_world , thanks, NVRAM and preloader files will be enough for check all. |
