01-13-2011, 23:31 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: Land of Lakes and Volcanoes Age: 51
Member: 111014 Status: Offline Thanks Meter: 132 | COM2 [VCP0] selected module v3.70 Device: GLP-138GT Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:96EE:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 2 record(s) TCL-ID is absent startup code area #1 record #1 is damaged, recalculation required startup code area #1 record #2 is damaged, recalculation required rom info detection finished device-id: 9006B1E2 rom info ver: 04 sw version: CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_T ELNI_GT_T4S1_OV7690_1P5441_NV.BIN project-id: C2012_1.8_TELNI_GT_T4S1_OV7690_1P5441_NV, FC02CE24 code offset: 00000000 ffs offset/size [01]: 00900000/00700000 rom info structure: [protected] type (04), 2 record(s) TCL-ID is absent ffs/eeprom address assigned: 00900000 startup code area #1 check... rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.9006B1E2.[CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_T ELNI_GT_T4S1_OV7690_1P5441_NV.BIN_24CE02FC].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.9006B1E2._CELLONSZ 23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_TELNI_GT_ T4S1_OV7690_1P5441_NV.BIN_24CE02FC_.rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.90 06B1E2.[CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_T ELNI_GT_T4S1_OV7690_1P5441_NV.BIN_24CE02FC].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.90 06B1E2._CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C20 12_1_8_TELNI_GT_T4S1_OV7690_1P5441_NV.BIN_24CE02FC _.rpl ==================== warning: unknown firmware: CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_T ELNI_GT_T4S1_OV7690_1P5441_NV.BIN_24CE02FC Unknown firmware found (v.3.70, database date: 30.11.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_T ELNI_GT_T4S1_OV7690_1P5441_NV.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.9006B1E2.[CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_T ELNI_GT_T4S1_OV7690_1P5441_NV.BIN_1D01A594].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\id.9006B1E2._CELLONSZ 23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_TELNI_GT_ T4S1_OV7690_1P5441_NV.BIN_1D01A594_.rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.90 06B1E2.[CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_T ELNI_GT_T4S1_OV7690_1P5441_NV.BIN_1D01A594].rpl rpl file not found: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.90 06B1E2._CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C20 12_1_8_TELNI_GT_T4S1_OV7690_1P5441_NV.BIN_1D01A594 _.rpl ==================== warning: unknown firmware: CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_T ELNI_GT_T4S1_OV7690_1P5441_NV.BIN_1D01A594 Unknown firmware found (v.3.70, database date: 30.11.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012_1_8_T ELNI_GT_T4S1_OV7690_1P5441_NV.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: GLP-138GT_CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012 _1_8_TELNI_GT_T4S1_OV7690_1P5441_NV__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\GLP-138GT_CELLONSZ23C_07B_PCB01_GPRS_MT6223P_S00.C2012 _1_8_TELNI_GT_T4S1_OV7690_1P5441_NV__ffs_20110113-162312.B0E.bin flash: 2088C4FFFF0013:2088C400000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................. required data found flash: 2088C4FFFF0013:2088C400000000 flash: 2088C4FFFF0013:2088C400000000 Write: area 1 (pass 1) .............................................. area 1 patch applied Ok detecting parameters to apply patch area 2... .................................................. .............. error: area 2 can not apply patch Special operation Done ====> Write ... flash: 2088C4FFFF0013:2088C400000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 9 min 35 sec Remove/Install battery now ! I have full flash if you need it, for improve smart fast unlocking.. |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
