12-27-2015, 08:23 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Satkhira khulna Bangladesh
Member: 1716947 Status: Offline Sonork: 100.1661965 Thanks Meter: 195 | Gphone T88 6531CA Read code and Read Flash done with CM2 Log here.. Chinese Miracle II [SPD module] v 1.09 Operation : Read User Code [ v1.09 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 008C 0025 0037 0000 [0] Flash VEN : [0] Flash CAP : 00800000 Check data... Can take some time User Code : 2125 Done! Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Read FullFlash [ v1.09 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 008C 0025 0037 0000 [0] Flash VEN : [0] Flash CAP : 00800000 Read Flash Content Read Ok , collect info Platform : MOCOR_12B_6531.W13.11_Release Project : SC6531_PDA HWInfo : SC6531_PDA Compile : 06-30-2015 10:07:24 Set FileInfo : Model Vendor : Gphone Model Name : T88 ExtInfo Data : 6531CA Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MO COR_12B_6531.W13.11_Release_06302015100724_6531CA_ _Gphone-T88.bin Done! Elapsed: 00:01:01 Reconnect Power/Cable! |
