03-21-2010, 17:24 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | After safe format the phone (Sigmatel S88) displays text -"Not Calibrated" on the screen and it doesn't ask for calibration manually like usually every phone asks to do with pen. The problem is even after trying all calibration methods with Infinity the problem remains same. Wr. |
04-27-2010, 14:03 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
04-28-2010, 12:23 | #12 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 752540 Status: Offline Thanks Meter: 18 | module v3.11 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:4390:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.11, database date: 18.03.2010): D386_PCB01_GPRS_MT6223_S00.SW_V00_03_YIDALONG.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 07 sw version: D386_PCB01_GPRS_MT6223_S00.SW_V00_03_YIDALONG.BIN project-id: D386.SW.V00.03.YIDALONG, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: D386_PCB01_GPRS_MT6223_S00.SW_V00_03_YIDALONG__ffs ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\D386_PCB01_GPRS_M T6223_S00.SW_V00_03_YIDALONG__ffs_20100428-164559.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 4 min 52 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
04-29-2010, 22:59 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! 1. set multimeter to voltage measuring. 2. power Onphone 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone must be powered On) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
05-08-2010, 03:10 | #15 (permalink) |
Freak Poster Join Date: Sep 2008 Location: delhi
Member: 857876 Status: Offline Sonork: cellexpert-33 Thanks Meter: 63 | RapidShare: 1-CLICK Web hosting - Easy Filehosting this is tested 100% working eeprom, (use by infinity) i have done many sets by this file. don't forget press thanks button. |
The Following User Says Thank You to cellexpert For This Useful Post: |
pls help: Error : box is not calibrated | freddy black | DreamBox | 1 | 03-28-2008 13:30 |
Error: Box is not Calibrated | livewirecebu | DreamBox | 1 | 03-24-2008 12:31 |
I can not calibrate box at all............ | The Repair Shop | UST Pro II | 15 | 11-02-2007 01:56 |
Error : You use not calibrated device | ocelular | DreamBox | 10 | 04-24-2007 15:04 |
Help Still Can Not Calibrate Ust Pro 2 | AbdulKadir | UST Pro II | 1 | 03-20-2006 14:53 |
