09-20-2015, 08:53 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: beawar (rajsthan)
Member: 764695 Status: Offline Sonork: 100.1627861 Thanks Meter: 45 | Micromax Q380 read firmware error 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 700100563130303038063A4132CD526F DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : 80001 [eMMC] : FLASH_CID : 700100563130303038063A4132CD526F [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Micromax ProdName : Q380 ProdModel : Micromax Q380 Device : Q380 AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : MMX_Q380_SW_V8.0.9_HW_V1.0_160615 [Read Ok] : preloader_zaw720.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Error] : Bad EXT data Looks like unusable file , break! Read Ok , collect info Brand : Micromax ProdName : Q380 ProdModel : Micromax Q380 Device : Q380 AndroidVer: 5.0 MTKxCPU : MT6582 MTKxPRJ : MMX_Q380_SW_V8.0.9_HW_V1.0_160615 File conversion error, file already exists! Saved as default! Done! Elapsed: 00:08:03 Reconnect Power/Cable! |
09-20-2015, 11:59 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Ways there is ONLY WITH USERDATA LOST! 1. Repair EXT in service tab. Then read fw. If still will be same - that mean phone is FACTORY encrypted. 2. If in Step 1 phone ENCRYPTED - Repair EXT , then power on phone, fastly press Read flash and insert cable in phone. |
