Old 04-25-2008, 19:54   #1 (permalink)
pr1mux's Avatar
Member: 218901
Thanks Meter: 64
Gtran N120 Pinout
hello guys, i need a picture from GTRAN N120 'couse i already make a cable but does't work....
check this:
RJ45 = 7-8 GND, 2 TX, 3 RX
Phone pin= 2 GND, 5 TX, 11 RX.
that's i did't but does't work, i connected, Rj45 GND (7-8) TO PhonePin(2) RX to RX and TX to TX and too, RX to TX but nada.
Old 04-25-2008, 20:02   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Gnd to Gnd
Then try again Rx to Rx, Tx to Tx.
If still no luck: swap Rx <-> Tx wires
Old 05-03-2008, 16:16   #3 (permalink)
Member: 126522
Thanks Meter: 10
gtran
hi support still no solution for unlocking gtran n120 ??????????
Old 05-03-2008, 23:09   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
unlocking what exactly?
Old 05-06-2008, 13:27   #5 (permalink)
Member: 126522
Thanks Meter: 10
gtran
unlock this phone model gtran n120 ,unlock sp
Old 05-06-2008, 17:21   #6 (permalink)
Member: 148515
hello!
http:///vbb/showpo...61&postcount=1
have you tried with this version?
Old 05-08-2008, 16:37   #7 (permalink)
Member: 126522
Thanks Meter: 10
gtran n 120
sir i try with MModule" v2.15 but no result i try with last version the same thig it stil locked (i read code ,smart fast stander fast but stil locked
Old 05-08-2008, 21:04   #8 (permalink)
Member: 148515
hello!
please read out full flash backup and upload to www.rapidshare.com
i will look in file where could lock code hide
Old 06-06-2008, 14:31   #9 (permalink)
Member: 126522
Thanks Meter: 10
gtran 120
wen i try to read the software it wil give me an error
sir i wan to now if this phone model can realy unlock
Old 06-06-2008, 15:30   #10 (permalink)
Member: 148515
hello!
which error?
Old 06-30-2009, 06:03   #11 (permalink)
Member: 483807
Checking data, wait...
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
error: boot initialization step #2 failed: A0
error: boot initialization step #3 failed: A0
19200 fixed
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 4 sec
Remove/Install battery now !
Gtran N120 no unlock ricardo ariza a Infinity-Box 17 11-26-2010 17:54
Gtran N120 pinout urecel Infinity-Box 1 02-19-2010 10:30
Gtran N120 stefan_162 Infinity-Box 60 11-14-2008 20:55
gtran n120 I could not unlock the phone manuelalejandro Infinity-Box 1 05-30-2008 07:33
Unlock Gtran N120 hvalero2001 Infinity-Box 2 04-20-2008 02:46
Page generated in 0.21330 seconds with 9 queries
