Gucci G629 socket to Infinity box ***** G629 I would like to make it join on INFINITY BOX Pin Finder. How let me do it? I do not have a socket to it, only a factory usb cable. Please help Infinity Support. |
Hello, What is this phone connector type ? |
There is a socket that I cannot identify on him unfortunately. Pinfinder is not socket like this. May he not be on the panel? |
Hello, Do you see any kind of connector at bottom side of phone ? |
"Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:3803:0004 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01" NO reading FULL FLASH! What is it necessary to put in another place? |
READ GENERAL INFORMATION : Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: M1234525_GEMINI_HW Software version: MAUI.GEMINI.W08.12" Software date: 2006.06.14 Barcode: GC629G_S09178033E 10 imei: 354752010000792 imei: 135790246811220 Finished, time used: 7 sec Power off phone now ! |
Did you tried with lower baud speed??? |
@GSMagic As I can see you have found the pinout and you can connect phone with software. What is the problem now ? I do not see any errors in log, I see only truncated log text. Please, make detailed problem description so we will be able to understand how to help you. |
==== log: [2008.11.17. 16:48:01] ==== COM5 selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:3803:0004 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN ver. sw 2: MAUI.GEMINI.W08.12, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00710000 Detected eeprom/ffs address is non-standard: 00710000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address confirmed by user: 00710000 detecting eeprom/ffs size... eeprom/ffs size: 008F0000 ffs chip: 00 eeprom/ffs area: 00000000:00710000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]... warning: wrong data size at 0x00001C00, retry... read error recovered warning: wrong data size at 0x00007400, retry... read error recovered warning: wrong data size at 0x0000C800, retry... read error recovered file saved: D:\Program Files\InfinityBox\ChineseMiracle\flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]_20081117-164854.B0M.bin Finished, time used: 36 sec Remove/Install battery now |
The Mobile : ***** G629 (chinese clone) No read full flash! Whether why? |
Hello, Please, explain what is the problem ! As I can see from log backup was done and file was saved: D:\Program Files\InfinityBox\ChineseMiracle\flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]_20081117-164854.B0M.bin So, what is the problem, we need to know more information ! Also, what cable you have used ? |
reading: flash[M1234525_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12.BIN]... warning: wrong data size at 0x00001C00, retry... read error recovered warning: wrong data size at 0x00007400, retry... read error recovered !!!!!!!!!!!!!!!! He cannot read the content. 0 bytes are the rescued data. The cable is perfect. The log a file implies the mistake. Somebody else has a problem like this on the internet. But we the trouble? The Infinity-box Chinese Miracle.exe does not know this telephone??? |
Man... I become little bit angry because you have ignored my questions. Infinity-Box is The best software for this kind of phones, if phone can be booted (in your case it was) this means that Infinity-Box know this model and can repair it ! If you unable to use software well you must read documentation and ask advices from experienced users and programmers ! My question again: What cable you have used ? I ask you about this because many Chinese zero-quality factories produce now zero-quality cables based on Prolific chip, and many greedy people buy this kind of cheap crap, as a result in many cases this kind of cables can not be used well with high-quality software and as a result many "zero quality cable lovers" start to talk about bugs in our software, but in fact all problems is a result of "saved money" and low-quality cables ! Do you understand now why you must make an answer or easy question ? |
Your answer was big strong one. I did nearly 150 pieces of telephone Infinity box. Infinity Plus,Pinfinder adaptor, RJ45 cable and the cable soldering the telephone is for inside. I write a Hungarian and Slovak language into it,with full translation. Maximally in detail. I did all of the telephones until now with these cables. All the best quality cable,that the you I bought from resellers. For example GSMSERVER.COM. I am sorry for it if you look at this much for unfortunate one. Indulgence, that I asked altogether.:mad: |
