Gx761 flash promble GX761 White sceen COM5 [VCP0] selected module v3.19 Device: ZTE-X761 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00[1].X761_Z2_SF_BFFA106_En_Fr_Es_Vodafone-Indie.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:2403:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C2659 8C4.[ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 06.BIN_5DD3CF59].rpl rom info detection finished device-id: C26598C4 rom info ver: 04 sw version: ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_BFFA1 06.BIN project-id: X761_Z2_SF_BFFA106, 59CFD35D code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__system_log_C26598C4_5DD3CF59_20100407-142729.B0X.bin Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\ZTE-X761_ZTEMT25_07A_PCB01_GPRS_MT6225_S00.X761_Z2_SF_ BFFA106__system_log_C26598C4_5DD3CF59_20100407-142841.B0X.bin Finished, time used: 1 min 45 sec Remove/Install battery now ! |
Hello, Sorry, I did not understand well, what is the problem with flashing ? |
bro my promble gx761 flash complet phone show few second vodafone logo phone going White sceen bilnk |
Hello, Try to flash phone with firmware + eeprom file, you can select firmware and eeprom with the same version (version is shown in file name). |
