06-02-2020, 06:16 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,801 | h mobile spd 6820 cannot reset only detected by svc Prof Kefah, [٠١.٠٦.٢٠ ٢١:١٨] Card found : 41DEDF35 , v0143 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Reset Settings [ v1.06 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.06 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Error : Boot Failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! SPRD mode : SC6531 : REV : 0000 : NOR : [ 4MB ] Operation : Identify [ v1.06 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! ModemInfo : Platform Version: MOCOR_880XG_MODEM_W13.39_Debug Project Version: sc6820_modem BASE Version: DM_BASE_12A_W13.39 HW Version: sc6820_modem CMP_Time : 09-29-2013 17:39:12 SecInfo : IMEI[1] : 354741063317904 IMEI[2] : 354741063317912 IMEI[3] : 000000000000000 WIFIMAC : 0027158055F7 BT_MAC : 112730200853 Done! Elapsed: 00:00:45 Reconnect Power/Cable! Operation : Read Flash [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v1.06 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v1.06 ] BootMode : SVC 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! ModemInfo : Platform Version: MOCOR_880XG_MODEM_W13.39_Debug Project Version: sc6820_modem BASE Version: DM_BASE_12A_W13.39 HW Version: sc6820_modem CMP_Time : 09-29-2013 17:39:12 SecInfo : IMEI[1] : 354741063317904 IMEI[2] : 354741063317912 IMEI[3] : 000000000000000 WIFIMAC : 0027158055F7 BT_MAC : 112730200853 Done! Elapsed: 00:00:45 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Error : Boot Failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Done! Elapsed: 00:00:32 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Done! Elapsed: 00:01:07 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v1.06 ] BootMode : FLASH 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Read UserCode [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! UserCode : Not set! Done! Elapsed: 00:01:31 Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Done! Elapsed: 00:01:13 Reconnect Power/Cable! SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB] Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Error : Boot Failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Done! Elapsed: 00:00:29 Reconnect Power/Cable! SPRD mode : SC6531 : REV : A000 : NOR : [ 4MB ] SPRD mode : SC6531 : REV : C000 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.06 ] 1. Power off device 2. Not hold any key on device! 3. Insert cable and battery in device! Wait for device ... Device Connected! Enter SVC ... Waiting Device ... Check SVC ... SVC : DiagChannel opened! Boot Done! Done! Elapsed: 00:00:33 Reconnect Power/Cable! SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ] |
06-02-2020, 07:44 | #2 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | If you have stock rom for this phone or similar device fw you can write user data only after phone will be reset. |
The Following User Says Thank You to mbiborna For This Useful Post: |
