Old 02-10-2008, 15:35   #1 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
H688 TV phone second sim "emergency" calls
hi all....
i have H688 [tv phone]
this is the firmware on it
MTK26_05C_MASTER_PCB01_GPRS_MT6226_S01.MAUI_05C_W0 6_16
the problem is that the phone has 2 lines
one of them is working fine, the other one is emergency calls always
i formated both ffs for both MCUs
i changed IMEI
i made repair security area.
same problem, this is the full info:
Hardware version: MT6226, E02
Hardware version: MALATA26_05C_HW
Software version: MAUI.05C.W06.16"
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 555555555555558
how can i know the other IMEI of the phone?
thanks in advance
Mansi
Old 02-10-2008, 19:53   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i would advice to write no just any number instead of IMEI, but write some valid IMEI from working set.
first IMEI you can see by typing *#06#
second IMEI you can see on GSM tester or connect infiniy box to CPU2 terminals and read out phone info.
please, write there some Vaild IMEI number, not 55555555555555
and post result
Old 02-10-2008, 20:18   #3 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
unfortunately i returned the set back to the customer, but any way, i have tried to write correct IMEI [valied IMEI like 350........], for both CPU's, and i got same result, if the customer give it back to me, then i will try another time with [2nd CPU].
thank you for the help any way.
Mansi
Old 02-10-2008, 20:38   #4 (permalink)
Member: 148515
hello!
if phone will return to your hands- also pay attention if it is possible to see available networks in "Netowrk search" menu.
Old 02-10-2008, 20:41   #5 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
ok i will.
thanks for your help
Mansi
Old 02-11-2008, 09:50   #6 (permalink)
sayedhas's Avatar
Member: 420598
Thanks Meter: 135
hello!
I HAVE THE SAME PROPLEM IN ANYCOOL 66+
SO PLZ INFINITY MOR EXPLAIN
Old 02-11-2008, 21:38   #7 (permalink)
Member: 148515
hello mr. sayedhas!
first, you explane what means "same problem"
which sim card is not working? first or second?
did you check for IMEIs? both correct?
did you try to write new IMEIs to both phone parts?
Old 02-16-2008, 01:50   #8 (permalink)
Temporary banned !!
Member: 148045
Thanks Meter: 17
hi
i have same problem
frist sim emergency mode but second work fine
when i try to manua search i see all network when i try to connect to sim network phone show try again later
i try to flash phone wit flash from support area(flash+epprom)
make repair and repair iemi
also how can i write second iemi
thk
Old 02-16-2008, 03:54   #9 (permalink)
Member: 148515
hello!
first CPU operation you doing via pinout for CPU_a
second CPU operation you doing via pinout for CPU_b
i think in your case you just need to set correct (valid) IMEI for both phone parts
try this and reply
Old 02-28-2008, 06:51   #10 (permalink)
Member: 125482
Thanks Meter: 30
can i write the same(valid) imie for both cpu or i can write 2 diffrant imie ?
Old 02-28-2008, 08:18   #11 (permalink)
Member: 125482
Thanks Meter: 30
sometimes its hardware problem.
Old 02-28-2008, 17:22   #12 (permalink)
Member: 148515
hello!
i would advice not to write to both parts 1 IMEI.
In some countrys operator is not allowing two same IMEIs to stay in one network.
I will tell more: some country operators block phones where last IMEI check digit is incorrect.
that is why our soft always calculate valid last IMEI check digit
Old 03-17-2008, 09:09   #13 (permalink)
Member: 39948
Thanks Meter: 68
How can i read second cpu, because, i read fullflash the second cpu, after downloading bootloader, phone is always on it self.
may i know where is cpu2 power button?
Thanks
Old 03-17-2008, 10:28   #14 (permalink)
Member: 148515
hello!
CPU 2 power button is same as CPU1.
when you booting second MCU phone acts like this:
1. you press power button and hold it.
2. Phone start normaly, you can see "Insert SIM", but you still keep power button pressed!
3. after around 30seconds you will see that program detected second MCU
4. You still keep power button untill software asks to release it
Old 03-19-2008, 16:00   #15 (permalink)
Member: 39948
Thanks Meter: 68
hello!
Yes its work, BUT
See this thread
http:///showthread...51#post3170351
Post number 7
need Pinout Nokia N200 TV phone 2 sim virgix Infinity-Box 1 03-31-2009 21:37
TianXing TV C902 Dual SIM Card Phone with TV & Bluetooth - Silver IPMART ipmart WebShop 0 11-24-2008 12:00
TianXing TV C902 Dual SIM Card Phone with TV & Bluetooth IPMART ipmart WebShop 0 10-27-2008 15:50
PDA TV MOBILE A9000 imei second sim problem josephic HTC & PDA WM( With Touchscreen) 0 06-07-2008 18:31
mpeg4 P888i second sim call hang green bird Infinity-Box 4 04-23-2008 19:46
Page generated in 0.25307 seconds with 9 queries
