09-13-2010, 16:06 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: bulgaria Age: 45
Member: 560859 Status: Offline Sonork: 1594862 Thanks Meter: 17 | e71i COM4 [Serial2] selected module v3.22 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware editor_corrected_L011_ML_NWF_PCB01_GPRS_MT6235B_S0 1.L011_ML_NWF_TY8A_TV1_FM1_WIFI0_EN1_SM_ML_V4_06__ firmware_20100913-054820.B4M.bin.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... nfi scat area detected (3 areas) nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (230400)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: L011_ML_NWF_TY8A_TV1_FM1_WIFI0_EN1_SM_ML_V4.06 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: L011_ML_NWF_BOOTLOADER_V005_MT6235B_L011_ML_NWF_TY 8A_TV1_FM1_WIF nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: L011_ML_NWF_PCB01_GPRS_MT6235B_S01.L011_ML_NWF_TY8 A_TV1_FM1_WIFI0_EN1_SM_ML_V4_06.BIN project-id: L011_ML_NWF_TY8A_TV1_FM1_WIFI0_EN1_SM_ML_V4.06, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.22, database date: 02.09.2010): L011_ML_NWF_PCB01_GPRS_MT6235B_S01.L011_ML_NWF_TY8 A_TV1_FM1_WIFI0_EN1_SM_ML_V4_06.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... nfi scat area detected (3 areas) nfi area detection (3 cores) finished: Ok startup code area #1 check... error: done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . . . error: can not write flash: 0FA7:S_FT_SET_DOWNLOAD_BLOCK_FAIL error: last error: 0FA7:S_FT_SET_DOWNLOAD_BLOCK_FAIL Disconnect... done Finished, time used: 2 min 35 sec Remove/Install battery now ! |
successful format ( DEAD) new version E71i | zeroualot_7 | Infinity-Box | 8 | 12-31-2009 17:16 |
BX E71i Dual SIM Card Phone With TV & Bluetooth - White | IPMART | ipmart WebShop | 0 | 05-08-2009 09:00 |
E71i Dual SIM Card Phone With TV & Bluetooth - White | IPMART | ipmart WebShop | 0 | 04-08-2009 11:40 |
E71i Dual SIM Card Phone With TV & Bluetooth - Black | IPMART | ipmart WebShop | 0 | 04-08-2009 11:40 |
