10-02-2008, 12:04 | #3 (permalink) |
Freak Poster Join Date: Aug 2006 Location: tampa
Member: 333872 Status: Offline Thanks Meter: 32 | LOG reead in chinece miracle !!New firmware detected!!! this is mi log an sen flash reed to [email protected] please check... [email protected] COM1 [Serial0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1F41:514C high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.DDF22B4A.[E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN _6E1E62E1].rpl ==================== New firmware detected: E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: DDF22B4A identification#1 protocol ver: 04 ver. sw1: E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN ver. sw2: MAUI.05C.W06.28, 1E9DE191 ffs offset/size: 00D00000/00300000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00D00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00D00000 detecting eeprom/ffs size... eeprom/ffs size: 00300000 ffs chip: 00 eeprom/ffs area: 00000000:00D00000-00FFFFFF detecting ffs structure pass 1... ................... detect standard fat location pass #1... .................................................. .. detect extended fat location pass #1... ....................................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ................... detect standard fat location pass #1... ................................ detect standard fat offset pass #1... detect standard fat location pass #2... .................... detect extended fat location pass #2... ...... detect standard fat offset pass #2... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\system_log_DDF22B4A_E660_VEN_PCB01_GPRS_MT6226_S 01.MAUI_05C_W06_28.BIN_6E1E62E1_20081001-084900.B0X.bin Finished, time used: 98 sec Remove/Install battery now ! please support!!!! to unlock New firmware detected Last edited by edlho; 10-02-2008 at 12:07. Reason: New firmware detected |
10-03-2008, 16:29 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Thank you ! We have received flash backup file, need some time to check it carefully. Please, try to keep phone with you one more day and we will try to give you software for test. |
10-04-2008, 16:51 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, use this new software: http://rapidshare.com/files/15087603...v2.34.rar.html Try to unlock phone by "standard" method. In case of any problems try to unlock phone with other methods. Waiting for your results. |
10-05-2008, 05:45 | #11 (permalink) |
Member: 333872 Status: Offline Thanks Meter: 32 | Thank you ! Thank you ! The Haier wass unloked on the flay in standar methot.....wala phone is unloked Thank you ! best support of the all box Grasias amigos, el telefono esta libre, a la primera!!!!!!!!!!!!!!!!!!!!!!! Salu2 |
10-05-2008, 08:24 | #13 (permalink) |
Member: 333872 Status: Offline Thanks Meter: 32 | This is Mi log COM1 [Serial0] selected Device: Haier HG-A8 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:1F41:514C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (startup code #1) is Ok security area (startup code #1) backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.DD F22B4A.[E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN _6E1E62E1].rpl identification#1 detection finished device-id: DDF22B4A identification#1 protocol ver: 04 ver. sw1: E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN ver. sw2: MAUI.05C.W06.28, 1E9DE191 ffs offset/size: 00D00000/00300000 Detecting security area (startup code #2)... .................................................. .............. security area (startup code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN]... file saved: C:\Archivos de programa\InfinityBox\MModule\eeprom[E660_VEN_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_28.BIN]_20081005-003326.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... ................... flash: 2088C4FFFFFFFF:2088C400000000 flash: 2088C4FFFFFFFF:2088C400000000 Write: area 0/1 ............................................. additional parameters detected Ok Special operation Done Write... flash: 2088C4FFFFFFFF:2088C400000000 Write: eeprom Write Done Finalization... Finalization Done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\syste m_log_DDF22B4A_E660_VEN_PCB01_GPRS_MT6226_S01.MAUI _05C_W06_28.BIN_6E1E62E1_20081005-003434.B0X.bin Finished, time used: 375 sec Remove/Install battery now ! |
The Following User Says Thank You to edlho For This Useful Post: |
10-05-2008, 11:07 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
unlock sucefully Haier-HG-A8 | jmr | Infinity-Box | 2 | 01-09-2009 19:29 |
06 Oct 2008: Haier-HG-A8 model supported | InfinitySupport | Infinity-Box | 8 | 10-08-2008 20:59 |
Infinity-Box: Haier-HG-A8 model supported | InfinitySupport | Service Products News & Updates | 0 | 10-06-2008 19:38 |
Haier HG-A8 | yurais | Infinity-Box | 2 | 08-05-2008 13:30 |
Haier HG-T60 Unclocking | m3ntal170 | GSM Mobile Links | 1 | 02-02-2008 11:00 |
