12-24-2010, 07:48 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Hello infinity? A200N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5C DGB_S5LCD_V1_6_6__fullflash_20101223-135527.B0M.bin Fault.. 1- open camera 2- take picture 3- Go to gallery 4 -open photo folder 5- mobile restarted automatically. Job done by me . 1 - read full flash 2- write flash 3- formate ffs Also repair bad flash. Result Problem remains same . Any infinity expert plz tell me the solution for this . |
12-24-2010, 18:44 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make full backup and try following file: flashfiles/ChineseMiracle/_MT6225/N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6_16m_En_Ru_Gr_Fr_Es_De_Th_Vn_Tr_Hi_Far si_Ar.B0M.bin |
12-31-2010, 18:11 | #5 (permalink) |
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | I have done my job successfully. 1.Formate full flash. Download the original file from support. Write flash and done formate ffs Repaired imei. Phone is working perfect. Here is complete log. COM5 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6_16m_En_Ru_Gr_Fr_Es_De_Th_Vn_Tr_Hi_Far si_Ar.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1803:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.206B5C39.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN_8BBB2DD0].rpl rom info detection finished device-id: 206B5C39 rom info ver: 04 sw version: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6.BIN project-id: N66_ABROAD_5CDGB_S5LCD_V1.6.6, D02DBB8B code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_ S5LCD_V1_6_6__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\N66_ABROAD_PCB01_ GPRS_MT6225_S00.N66_ABROAD_5CDGB_S5LCD_V1_6_6__ffs _20101231-215300.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S 5LCD_V1_6_6__system_log_206B5C39_8BBB2DD0_20101231-215308.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_5CDGB_S 5LCD_V1_6_6__system_log_206B5C39_8BBB2DD0_20101231-215358.B0X.bin Finished, time used: 5 min 26 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? Formate ffs. COM5 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1803:000D status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: N66_ABROAD_5CDGB_S5LCD_V1.6.6 Version: GIONEE25_GEMINI_07B_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 139 warning: wrong packet cs warning: wrong packet cs items cleared: 139 of 139 building list... done items remains: 0 Finished, time used: 28 sec Remove/Install battery now ! Imei repairing. COM5 [VCP0] selected module v3.25 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 355790246811225 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1803:000D status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: N66_ABROAD_5CDGB_S5LCD_V1.6.6 Version: GIONEE25_GEMINI_07B_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... 5 11 done 67 byte(s) read verification... verification done: 35579024681122 Finished, time used: 18 sec Remove/Install battery now ! Very very big thanks to infinity. |
hello. does anyone have the c28 flashes | pmagroup | x1x to x45/x50 | 0 | 08-08-2001 12:27 |
Hello Could Someone Please Help Me??? | Shahid | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-23-2000 00:30 |
Hello , I have Bosch full 16 digits reader , if smb need mail me :) | Nec | Various | 6 | 04-29-2000 14:33 |
Hello, unlock 5110 | alidesign | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-13-2000 15:12 |
