hello infinity i need help i have just finde the righ pin out for chines miracle nokia n77 touch srceen with big lcd and i cannot see flash file in support area pleas i need ur help .my phone is restarted when inserted sim so i try to direct unlock here my log info COM4 selected Device: Autodetect Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished memory structure: 2nd [enhanced] (or higher) generation warning: make backup before any action ! warning: probably identification data damaged, power-on problem possible error: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.63F49E3F._BR26 _05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN_72A0E82E _.rpl warning: unknown identification structure: BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN_72A0 E82E error: ASK file can't be created, user action required: - find good working phone with the same firmware[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN] - make "Read detailed information, ask/rpl" operation - send "backup_system_log_..." file to support - make "Read Full Flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update identification detection finished device-id: 63F49E3F protocol version: 04 version sw1: BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN version sw2: BR26_35.11 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area detected[00000000]: 00E00000-00FFFFFF detecting structure pass 1... ................ detect standard location pass #1... .................................................. ...... detect extended location pass #1... .................................................. ... detect standard offset pass #1... detect standard data... layout detection complete eeprom element #1 detected ok reading [eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN]]... file saved: backup_eeprom[BR26_05C_PCB01_GPRS_MT6226_S01.BR26_35_11.BIN]_20070719-150724.B0E.bin flash: 01227E22202200:29EA0000000000 Check space Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... Finalization Done Write... flash: 01227E22202200:29EA0000000000 Write: eeprom Write Done Finished, time used: 486 sec Remove/Install battery now ! here is buckup eeprom for my phone http://www.sendspace.com/file/l2h4lj |
hi can u give me n77 pinout it verry urjent sir plssssss give me sir |
