01-23-2016, 12:39 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: Kabul City Afghanistan Age: 38
Member: 1600947 Status: Offline Sonork: 100.1627298 Thanks Meter: 772 | hello team pleas add more mtk cpu some cpu not support |
The Following 7 Users Say Thank You to abdulhaq_majroh For This Useful Post: |
01-23-2016, 12:51 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, About which mtk cpu are you taking about? Be specific. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
01-23-2016, 13:31 | #3 (permalink) |
Member: 1600947 Status: Offline Sonork: 100.1627298 Thanks Meter: 772 | hello sir i had that problem on many phone lick 10 minute ago clone Samsung gt-i9082 mt 6572 cant format or flash phone |
The Following 6 Users Say Thank You to abdulhaq_majroh For This Useful Post: |
01-24-2016, 12:23 | #9 (permalink) |
Member: 1600947 Status: Offline Sonork: 100.1627298 Thanks Meter: 772 | see this Operation : Remove Viruses [SmartAV] [ v1.40 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND Flash not supported yet! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to abdulhaq_majroh For This Useful Post: |
01-24-2016, 12:25 | #10 (permalink) |
Member: 1600947 Status: Offline Sonork: 100.1627298 Thanks Meter: 772 | see this again Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info , blank flash or wrong settings? Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to abdulhaq_majroh For This Useful Post: |
01-24-2016, 12:26 | #11 (permalink) |
Member: 1600947 Status: Offline Sonork: 100.1627298 Thanks Meter: 772 | see this one i had that problem a lot of phone Operation : Format FileSystem [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info , blank flash or wrong settings? Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to abdulhaq_majroh For This Useful Post: |
01-24-2016, 12:36 | #12 (permalink) |
Member: 1600947 Status: Offline Sonork: 100.1627298 Thanks Meter: 772 | hello team i have this problem with many brand and phone NAND Flash not supported yet! |
The Following User Says Thank You to abdulhaq_majroh For This Useful Post: |
01-24-2016, 13:38 | #13 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | And how it related with thread name? I told already - NAND WILL NOT BE SUPPORTED FOR AV! Now clear? |
