help with 2 sets Infinity Team i have Cect T888 & CNokia N972 the two sets with hang problem.... the two sets with CPU :- MT6226 i tried many times but i can't detecting pins by using pinfinder software version: 1.11 cable type: 1x12 (L12C) platform: MT62xx (autodetect) searching adapter at COM3... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 65 sec Power Off ! what is the problem here |
1 Attachment(s) FOR BATTER RESULT PINFINDER PUT THIS CAPA 470mf/10v and your problem is connector,cline connector, or chang,if no result rehit cpu. |
hello! yes, if you have problems with powering phone from pinfinder power- you must remove diode and set capacitor. procedure is described in user manual. only when phone can be powered On from pinfinder power- pinout can be found |
regards |
hello! for increasing box output voltage- you must desolder diode fronm infinity box. to solve not_powering_on problem- you must add capacitor to pinfinder box please check latest pinfinder user manual |
