help to alive Nokia E60i i got dead Nokia E60i chinese set. i readed info MIKI26_05C_PCB01_GPRS_MT6226_S01[1].V20_40_16m_En_Cn.B0M.bin from infinity website i got this file and flashed it MIKI26_05C_PCB01_GPRS_MT6226_S01[1].V20_15_16m_En_Cn.B0M.bin ==== log opened: [10/29/2007 8:22:20 AM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v1.60 S/N: 018F:010C Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... CM_Nokia-E60i_2x5pin_MIKI26_05C_PCB01_GPRS_MT6226_S01[1].V20_15_16m_En_Cn.B0M.bin loaded protocol ver: 04 ver. sw1: MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_15.BIN ver. sw2: V20.15 COM8 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom area in 1 chip(s)... flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom area Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address selected by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [eeprom]... file saved: backup_eeprom_20071029-082518.B0E.bin flash: 01227E22202200:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.83C39B41.[MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_15.BIN_3BD148 78].rpl identification detection finished Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware structure: 2nd [enhanced] (or higher) generation identification data damaged identification detection finished flash: 01227E22202200:29EA0000000000 flash: 01227E22202200:29EA0000000000 Write: rpl rpl restore ok Write Done file saved: backup_system_log_83C39B41_MIKI26_05C_PCB01_GPRS_M T6226_S01.V20_15.BIN_3BD14878_20071029-082619.B0X.bin Finished, time used: 143 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... COM8 [Serial2] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02]... Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: V20.15 Version: MIKI26_05C_HW detecting structure #2... done imei: 13579024681122 warning: wrong packet cs 127 of 160 items cleared 0 items remains Finished, time used: 102 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM8 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation identification data Ok identification data backup saved: id.83C39B41.[MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_15.BIN_3BD148 78].rpl identification detection finished device-id: 83C39B41 protocol ver: 04 ver. sw1: MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_15.BIN ver. sw2: V20.15 ffs offset/size: 00E00000/00200000 detecting eeprom area in 1 chip(s)... flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00E00000 detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF reading [eeprom[MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_15.BIN]]... file saved: backup_eeprom[MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_15.BIN]_20071029-082959.B0E.bin flash: 01227E22202200:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 01227E22202200:29EA0000000000 Write Done file saved: backup_system_log_83C39B41_MIKI26_05C_PCB01_GPRS_M T6226_S01.V20_15.BIN_3BD14878_20071029-083024.B0X.bin Finished, time used: 101 sec Remove/Install battery now ! first i flashed then click on Format FFS with Safe. i got on set but hang whenever i left power botton i got set. then click on Format FFS with complete but still dead. Whenever i click on Format FFS with Safe i get on set but hang and when i leave power botton i get dead. plz help me to alive my set....... |
1. make full flash backup for emergency case (use 921000 speed for fast operation) 2. select "safe" format method 3. make "format ffs" 4. remove/install battery 5. press and hold phone "Power" button during 30-40 sec to make phone Powered-On i got on set but when i click on write imei then i got error. not set is connect with computer. how i can i restore imei. |
Whenever i click on Format FFS with Safe method i get on set within 5 seconds but whenever i leave power botton i get again dead set. so sir how can i restore original imei because i have dead set. |
go to C:\Program Files\InfinityBox\Documentation & make little look here Infinity-Box_How_to_repair_dead_Chinese_phone_MT6226_MT6227 _etc_En.htm you must write rpl to your phone |
plz look carefully i have written rpl file. Write: Firmware structure: 2nd [enhanced] (or higher) generation identification data damaged identification detection finished flash: 01227E22202200:29EA0000000000 flash: 01227E22202200:29EA0000000000 Write: rpl rpl restore ok Write Done file saved: backup_system_log_83C39B41_MIKI26_05C_PCB01_GPRS_M T6226_S01.V20_15.BIN_3BD14878_20071029-082619.B0X.bin Finished, time used: 143 sec Remove/Install battery now ! try to understand i click on Format FFS with Safe method i got power on set within 5 minutes after click on bottom Format FFS but whenever i leave power botton i again dead set. when set goes to on set hang on start up menu....... i have tried many method but set not goes to on. on website E60i has only one firmware. |
try to write another firmware ps : you must read backup before traying anything |
i have already told you that there is no another firmware in net for E60i. i got only one firmware. |
no sir there many firmwares like --------------- CM_Nokia-8800_MIKI26_05C_PCB01_GPRS_MT6226_S01.V61_07_16m_E n_Vn_Ru.B0M.bin --------------- CM_Nokia-8800_MIKI26_05C_PCB01_GPRS_MT6226_S01.V61_08_16m_E n_Fr_Pt.B0M.bin --------------- CM_Nokia-E60i_2x5pin_MIKI26_05C_PCB01_GPRS_MT6226_S01.V20_1 5_16m_En_Cn.B0M.bin --------------- . . . . . . ps: all flash files with this name MIKI26_05C_PCB01_GPRS_M T6226 are the same |
i have flashed with these firmware but problem still no solve. CM_Nokia-E60i_2x5pin_MIKI26_05C_PCB01_GPRS_MT6226_S01[1].V20_15_16m_En_Cn.B0M CM_Nokia-8800-Sirocco_MIKI26_05C_PCB01_GPRS_MT6226_S01[1].V63_05_16m_En_Ru_Vn_w_eeprom.B0M CM_Nokia-8800_MIKI26_05C_PCB01_GPRS_MT6226M_S01[1].V61_18_16m_En_Ru-corrected_Vn.B0M CM_Nokia-8800_MIKI26_05C_PCB01_GPRS_MT6226M_S01[1].V61_18_16m_En_Ru_Vn.B0M CM_Nokia-8800_MIKI26_05C_PCB01_GPRS_MT6226M_S01[1].V61_15_16m_En_Ru_Vn.B0M CM_Nokia-8800_MIKI26_05C_PCB01_GPRS_MT6226M_S01[1].V61_11_16m_En_Vn_Ru.B0M CM_Nokia-8800_MIKI26_05C_PCB01_GPRS_MT6226_S01[1].V61_07_16m_En_Vn_Ru.B0M before flashing these firmwares set was getting on within 5 seconds when i click on Format FFS with Safe method. but when i left power botton i got again dead but now not getting on with any way. Plz me to solve thisn problem i m continue working with this set for 3 dayz. i have to fix this set problem. |
You must make ask/rpl calculation during flashing. Here is more info: http:///vbb/showthread.php?t=452251 |
i have made all flash files rpl. guide me in a perfect way like is it possible to repair Eprom flash file for alive my E60i set. otherwise i have made 7 to 8 rpl for this set |
hello! if you calculated RPL file for each flash file you mentioned above, but set was not get On- then only one way i see: find similar phone with exactly same version "MIKI26_05C_PCB01_GPRS_MT6226_S01[1].V20_40_16m_En_Cn" and read it out. after use it for restoring your dead phone. |
