Old 02-27-2020, 17:41   #1 (permalink)
Member: 2761624
Thanks Meter: 59
help extracting bin file read by cm2MT2
hello infinity team,plz help me on how i can extract the contents of bin file that has been read from tecno camon 11 cf7...i have a customer where his uncle is deceased so they need to access the information from the phone,so i used memory tool to dump user data partion..so please help on how i can get the info from the bin file
Operation : Memory Tool Init [ v2.07 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM135)
MODE : PRELOADER PORT
PORT : 135
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : PRELOADER PORT
MODE : TECNO : [Hovatek] Tecno Camon CF7K DA file | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6763
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 150100474536424D4203265268D435A9
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GE6BMB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A3E00000 [ 14.56 GB ]
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 498F9C09E15425C909F1EA88302B907
DA : USB : HIGH-SPEED
Boot done!
Set default path : C:\InfinityBox\CM2MT2\phdata\
Ready!
Operation : Read Memory
Reading selected partitions [1]
[0] Read partition : USERDATA
Saved to : C:\InfinityBox\CM2MT2\phdata\USERDATA.bin
Operation finished!
Old 02-27-2020, 18:31   #2 (permalink)
Member: 1043909
Thanks Meter: 60,921
PORT : 135
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Ready!
Operation finished!
It looks like you have got a fle already
Old 02-27-2020, 20:17   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
PORT : 135
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Ready!
Operation finished!
Make identify first.
Then tell, when device ask code?
Does it ask "to start android enter code"? or something similar?
Old 02-28-2020, 08:00   #4 (permalink)
Member: 2761624
Thanks Meter: 59
yes i have the file,but how can access the contents in the file??
Old 02-28-2020, 08:06   #5 (permalink)
Member: 2761624
Thanks Meter: 59
i did identify first..the user data its encrtpy..is it possible to extract this bin fil?
Operation : Identify [ v2.07 ]
PORT : 135
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Patch Level : O11019
Display ID : CA7-H633BCDK-O-180717V205
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-07-05
Build Time : 1531842309
Product Brand : TECNO
Product Manfct : TECNO MOBILE LIMITED
Product Model : TECNO CA7
Product Device : TECNO-CA7
Product Name : H633
Product Info : TECNO-CA7
Board Platform : mt6763
USERDATA : ENCRYPTED
Old 02-28-2020, 13:53   #6 (permalink)
JayDi's Avatar
Member: 462970
You can't access to content from encrypted data.
You not answer on my second part of question.
Old 02-28-2020, 14:33   #7 (permalink)
Member: 2761624
Thanks Meter: 59
yes sir its asking code to enter android..Any solution ?
Old 02-28-2020, 14:45   #8 (permalink)
JayDi's Avatar
Member: 462970
Can advise wait or search for CVE for your android version, kernel release, or exactly this device.
But since it mostly uncommon brand, bad luck. With using set fuse bits, it became hard task at all. Price for this ones can be with 5-6 zeroes after fisrt digit in usd.
The Following User Says Thank You to JayDi For This Useful Post:
Page generated in 0.18663 seconds with 8 queries
