06-12-2009, 12:18 | #1 (permalink) |
Junior Member Join Date: Dec 2006
Member: 403036 Status: Offline Thanks Meter: 1 | help with FLY MC100 Phone screen shows the boot ... When reaches 100%, then turns off the backlight. After 10-15 seconds, shuts down completely. Power remains in the 120 mA and will not change until you disconnect the battery. I've already flashed the phone of two files, downloaded from support: 1. Fly-MC100_LENOVO28_06B_PCB01_GPRS_MT6228_S02_2008-07-17_En_Ru.B4M.bin 2. Fly-MC100_LENOVO28_06B_PCB01_GPRS_MT6228_S02_S113_0801 03_rev1275_1283_En_Ru[1].B4M.bin Infinity Log: Code: COM6 [VCP2] selected module v2.76 Device: Fly-MC100 Checking data, wait... Action: write NAND flash read mode: 01 "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: LENOVO28_06B_PCB01_GPRS_MT6228_S02.BIN ver. sw 2: MAUI.06B.W07.16.MP.V30.F1, 378C5AF7 ffs offset/size: 02200000/01E00000 id-page1 Ok end mark #2 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 chip: 0031:0000:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 07 loader: 3.0840.00.00 NAND id: EC765A3F page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 external ram: 00000000 finalize connection... done emi configuration... ram size: 02000000 emi configuration done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0000:000000000000 [00000000] NAND: 00EC:0076005A003F [04200000] NOR chip is not installed Initialize Done Set baud ... 921600 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00010000 bytes)... detecting bootloader structure... warning: probably flash chip completely erased, no bootloader found nfi area detection finished: failed detecting bootloader structure by source file... source data: page only identification#1 protocol ver: 04 ver. sw 1: LENOVO28_06B_PCB01_GPRS_MT6228_S02.BIN ver. sw 2: MAUI.06B.W07.16.MP.V30.F1, 378C5AF7 ffs offset/size: 02200000/01E00000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished security area (code #1) calculation... done Identification Done Write ... 00006000 bytes sent write core area 1 of 3... 0032C400 bytes sent write core area 2 of 3... 00B57800 bytes sent write core area 3 of 3... 00439400 bytes sent formatting... ....................................................................................................Write Done Finished, time used: 658 sec Remove/Install battery now ! |
The Following User Says Thank You to yago55 For This Useful Post: |
05-09-2010, 08:53 | #6 (permalink) |
Banned Join Date: Nov 2009
Member: 1152995 Status: Offline Thanks Meter: 51 | phone have user code only bt can't read user code so i format after format 100% then hang i flash with all firmware bt phone now dead condition and now phone can't start i am not satisfied with infinity first time regards INDIAN USER |
05-09-2010, 11:13 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | why you did not make dull flash backup before flashing ? what was original firmware version ? you must charge battery and phone will be powered-on. |
05-09-2010, 11:33 | #8 (permalink) |
Member: 1152995 Status: Offline Thanks Meter: 51 | phone is Ok now thanks infinity HElp But still i can't write original imi.......when i try to change imi phone start and come to 100% then shutdown plz send me infinity help yahoo id INDIAN USER |
E72 keep restarting ..... any help with hardware solution?? | abu_nairoukh | Nokia Hardware & Hardware Repair | 4 | 12-14-2010 11:10 |
pls help me how to read keypad code Fly-MC100 | rajivmobil | Infinity-Box | 1 | 08-09-2009 15:23 |
Can't do anything with Fly B700 | domestik | Infinity-Box | 1 | 02-23-2009 17:59 |
Trouble with fly sx210 doesnt boot right | CHAGUA | Infinity-Box | 1 | 01-10-2009 18:20 |
plz help infinity fly sl399e | Shakeel Communication | Infinity-Box | 8 | 06-23-2008 09:06 |
