06-15-2016, 10:44 | #3 (permalink) |
Freak Poster Join Date: Sep 2007 Location: philippines
Member: 580233 Status: Offline Thanks Meter: 27 | logs: Operation : FlashIC ReadOnly/BadBlock Test [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x Android 5.x eMMC v1.0 Inf Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Prepare test data ... Test flow #0 ... Test flow passed! Test flow #1 ... Test flow passed! Test flow #2 ... Test flow passed! Test flow #3 ... Test flow passed! Test flow #4 ... Test flow passed! Test flow #5 ... Test flow passed! Finalize Ok! Test passed successfully! Elapsed: 00:00:59 Reconnect Power/Cable! |
06-15-2016, 11:16 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | FlashIC is alive. Are you sure about mobile have only one HW revision and it is compatible with all SW versions? Case as yours normally happen, when device have different HW revisions, which require different FW version. |
06-18-2016, 03:08 | #8 (permalink) |
Crazy Poster Join Date: Jun 2010 Location: cold place
Member: 1316900 Status: Offline Sonork: none Thanks Meter: 30 | hello mr.bench betita can u share your firmware i have same problem pls... |
The Following 2 Users Say Thank You to d'starter For This Useful Post: |
06-18-2016, 03:13 | #9 (permalink) | |
Member: 580233 Status: Offline Thanks Meter: 27 | Quote:
credit to the original owner of the firmware,.. SIR, OXYGEN... | |
06-18-2016, 03:16 | #10 (permalink) | |
06-18-2016, 03:17 | #11 (permalink) | |
06-18-2016, 03:18 | #12 (permalink) | |
06-18-2016, 03:20 | #13 (permalink) | |
credit to original owner of firmware sir oxygen,... | |
06-18-2016, 03:22 | #14 (permalink) | |
The Following User Says Thank You to bench betita For This Useful Post: |
