12-22-2016, 02:35 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: COLOMBIA
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | Help: I need Read FW ZTE A310 MSM8909 here log: Identify: Operation : Identify [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 02AD9F48 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 06F217CCC5C40FC1A9DD1EC4A1F9AD39 ID_BLOCK_L : 154491FE21623263B19361D40202109F Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! read FW: Operation : Read Flash [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Please help. thx in advance. |
12-22-2016, 03:55 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | hi mr jaydi hava some problem of this user can help to solved this Operation : Identify [ v1.06 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8909] ID_BLOCK_S : 055A7F59 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 35C306FFF4F73ED25ACC21D590EABE0A ID_BLOCK_L : 4017C2AB72379DD6ECE03463AD6F65C2 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
12-22-2016, 05:21 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Unsupported SecureType. Can't say when this device will work with CM2. We adding new phones in every update, if something will be - we will let know. |
12-22-2016, 07:45 | #4 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Mr jaydi have uptade.zip of a310 but cant flash this file can helpyou for add this model? My phone is imei null by clear nvm and this model have boot protect Wait for any help thanks |
