12-19-2008, 09:17 | #1 (permalink) |
Junior Member Join Date: Jul 2007 Location: phillipines Age: 41
Member: 546234 Status: Offline Thanks Meter: 2 | help infinity product supporter any solution "Please, contact to Support and attach last created backup file in bug-report." COM4 [VCP0] selected Device: Panasonic-X700,X701 Checking data, wait... Action: TestMode On Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... boot answer: 02 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0089:8862 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-X700,X701_eeprom-sta_20081219-160543.30E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\falcon_eep65535.cfg error: can't load database v.65535 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-X700,X701_eeprom-sec_20081219-160547.30E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Panasonic-X700,X701_eeprom-complete_20081219-160607.30E.bin backup critical area Done Check memory... loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\falcon_eep65535.cfg error: can't load database v.65535 error: operation terminated. Probably unsupported eeprom structure. Please, contact to Support and attach last created backup file in bug-report. Check memory Failed Finished, Remove/Install battery now ! Time used: 39 sec here is my back http://www.4shared.com/file/76666674...16060730E.html http://www.4shared.com/file/76666699...16054730E.html http://www.4shared.com/file/76666716...16041230E.html http://www.4shared.com/file/76666729...16054330E.html thanks infinity team |
12-19-2008, 13:31 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, There is no any good solution for "X700 reboot" problem yet. You can try top flash phone with eeprom file from support area, but there is not so big chance that phone will be repaired. |
@infinity product supporter,why not listed a harmfull sw that can killed samrtcard | mantok | Infinity-Box | 19 | 03-18-2010 15:58 |
Infinity product supporter | akashub | Infinity-Box | 3 | 02-14-2010 17:00 |
where is infinity product supporter........... | unlock & flash | Infinity-Box | 2 | 09-16-2008 20:15 |
infinity product supporter | ruff_tee | Infinity-Box | 1 | 06-18-2008 08:05 |
No help from product Supporters | sharaz191 | DreamBox | 3 | 05-05-2008 10:32 |
