04-09-2008, 11:05 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 231650 Status: Offline Thanks Meter: 51 | help infinity team no set conecting here is an example COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:E241:4028 high speed disabled boot step size: 0002 error: bootcode load error: Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 8 sec Remove/Install battery now ! every set gives this error whether it is a china mobile or any other mobile like c2500lg or c 168 motorola and all mobiles gives same error which i reported above plz help me i am in great worry |
04-09-2008, 14:44 | #2 (permalink) |
Member: 231650 Status: Offline Thanks Meter: 51 | secondly sometimes it gives this error error sending apdu smart card api error #80100069 the smart card has been removed so the further communication is not possible but if i recoonect box it is ok now when i try to use it when set is on it works fine like just i changed imei of lg kg270 here is log Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Repair imei... software version: KG270P16-92-V10c-***-XX-MAR 28 2007+0 original imei: 35*********xx new imei: 35*********xx imei verification Ok Done Finished but when i try to do reset settings for this function phone should be off it gives me the same error COM6 [VCP0] selected Device: LG KG270 Checking data, wait... Action: reset Boot... Press and HOLD Power button now ! loading... error: can't run preloader: Release Power button now Boot Failed Finished, Remove/Install battery now ! Time used: 16 sec same is with all chineese set so plz advise me what to do |
04-10-2008, 11:39 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If box worked before and now stop to work well I think you need to check all cables and contacts. Also if you see smart-card error from time to time the problem maybe in bad contacts in sim-holder. Open box, clean smart-card contacts carefully, check that RJ45 soldering is good. Also you can try to use Infinity-Box smart-card with another card reader and you can try to use another cables, so it will be possible to understand where is the problem. |
infinity box not working plz help infinity team | Y2ksalman | Infinity-Box | 21 | 01-18-2011 00:51 |
Help infinity team china set dead after full format? | malikawan | Infinity-Box | 3 | 10-02-2009 10:38 |
No Flash File Is Present For 6300r ....urgently Help Infinity Team | sairat | Infinity-Box | 5 | 02-24-2008 23:17 |
Need Help Infinity Team..... No Imei Option | bukshi_mobile | Infinity-Box | 1 | 02-07-2008 18:51 |
HELP INFINITY TEAM c168 unlock no succes | vinay_sharma | Infinity-Box | 1 | 07-18-2007 14:25 |
