08-04-2009, 23:50 | #1 (permalink) |
Insane Poster Join Date: Mar 2008
Member: 721725 Status: Offline Thanks Meter: 7 | Problem, Unlocking Gtrans N120 I have tried to unlock two Gtrans N120, but After process. The SIM isn´t recognized by the phone. That´s the opperation log. I hope someone can help me. ==== log: [04/08/2009 19:00:40] ==== COM11 [VCP0] selected modulo v2.79 Servicio: Gtran-N120 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "sp-unlock" Metodo unlock: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Mantenga Presionado el boton Power ! 19200 fixed Conectando, espere... Iniciando [6227:8A02:8A01]... CPU: MT6227 chip: 0031:0F41:1D0C status: FF Tamaño del boot packet: 0400 Deje de presionar el boton power ahora ! Boot Done Iniciar ... detecting chip #00 in region #00... Flash 89881500010001:89881500000000 Flash Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb numero de flash chip/regiones detectadas: 01/01 Iniciar Done Seleccionar velocidad ... 115200 Seleccionar velocidad Done Iniciar bootcode ... Iniciar bootcode Done Comprobar la integridad del firmware ... detect device identification#1... fase de deteccion #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN ver. sw 2: MAUI.06A.W06.44.MP.V20, 00000000 ffs offset/size: 00E00000/001E0000 detect device identification#2... fase de deteccion #1... . detect device identification#2 finished Estado sim-lock: unknown Comprobar la integridad del firmware Done Comprobar el contenido del firmware ... Comprobar el contenido del firmware Done Backup de datos requeridos ... leyendo Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20__ffs... Archivo guardado: C:\Archivos de programa\InfinityBox\MModule\Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20__ffs_20090804-190429.B0E.bin Flash 89881500010001:89881500000000 Backup de datos requeridos Done Revisión de datos requeridos ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Revisión de datos requeridos Done Operacion Especial ... detecting additional parameters... .............................................. Flash 89881500010001:89881500000000 Flash 89881500010001:89881500000000 Escribir area 0/1 .................. additional parameters detected Ok Operacion Especial Done Escribir ... Flash 89881500010001:89881500000000 Escribir eeprom Escribir Done Finalizado ... Finalizado Done Finalizado, tiempo usado: 457 sec Quite/coloque la bateria ahora ! ==== log: [04/08/2009 19:11:27] ==== COM11 [VCP0] selected modulo v2.79 Action: Leer Codigos Metodo unlock: read codes Modelo: Gtran-N120 Checkeando datos, espere... El Telefono deberia estar APAGADO ! Mantenga Presionado el boton Power ! error: No se puede activar el test mode error: La operación falló ! Finalizado, tiempo usado: 44 sec Quite/coloque la bateria ahora ! ==== log: [04/08/2009 19:12:33] ==== COM11 [VCP0] selected modulo v2.79 Servicio: Gtran-N120 Checkeando datos, espere... Habilitada la deteccion avanzada del chip Action: "sp-unlock" Metodo unlock: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Mantenga Presionado el boton Power ! error: No se puede detectar Deje de presionar el boton power ahora ! En caso de problemas con la conexion inincial: on/off "Autoseleccionar Boot baudrate" Boot Fail Finalizado, tiempo usado: 22 sec Quite/coloque la bateria ahora ! |
08-09-2009, 18:31 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Flash phone with firmware from support area and make format ffs. Phone should be locked back and it will be able to accept original sim card. |
09-11-2009, 00:13 | #7 (permalink) | |
Member: 721725 Status: Offline Thanks Meter: 7 | Quote:
I have two phones in this situation, his owners reclaim their phones. I hope you can found any solution for it, as you promised me some month ago. regards, Will_traveler | |
11-05-2009, 00:24 | #8 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: colombia
Member: 403517 Status: Offline Thanks Meter: 23 | Quote:
COM7 [VCP0] selected module v2.92 Device: Gtran-N120 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:C141:15B4 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_V20.B IN ver. sw 2: MAUI.06A.W06.44.MP.V20, 00000000 address offset: 00000000 ffs offset/size: 00E00000/001E0000 ffs address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Gtran-N120_KCM_PCB01_GPRS_MT6227_S01.MAUI_06A_W06_44_MP_ V20__ffs_20091104-180841.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done Special operation ... detecting parameters to apply patch area 1... .................................................. .............. error: area 1 can not apply patch Special operation Done Write ... flash: 89881500010001:89881500000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 303 sec ??? any solution ???? support infinty team? | |
Help Unlock Gtran N120 | HECTORTULUA | Infinity-Box | 20 | 03-17-2011 15:16 |
gtran n120 unlock problem | ahmertelecom | Infinity-Box | 10 | 10-19-2009 09:47 |
Problems with a GTran N120 | hvalero2001 | Infinity-Box | 4 | 10-29-2008 20:47 |
Unlock Gtran N120 | jorge1545 | Infinity-Box | 1 | 08-11-2008 22:26 |
Unlock Gtran N120 | hvalero2001 | Infinity-Box | 2 | 04-20-2008 02:46 |
