help me 6300 help me pls pinout not work of the modele . 7pin. ic 661u rm217 fcc id ppirm-217. im tested pinout 1 tx 2. *#0044# set language englesh |
Hello there.. Just open ur fone and see rx tx gnd on PCB solder cable wires it should work jus fine Br, TOm |
no see rx and tx my friend |
hello! start from testing system connector with multimeter: 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx if no such voltages- post PCB picture, maybe someone will recognise it |
if your mobile connector type is simular as 2x7 but it work with 2x5 connector i have test it and pinout is so : 5-GND 4-TX 9-RX salem_gsm ;) |
very very urgent reply see posted date 03-11-09, 07:27 PM |
