09-02-2011, 23:18 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
09-03-2011, 04:42 | #3 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Tizayuca
Member: 859004 Status: Offline Thanks Meter: 10 | It does not work, make error, here the log of operation: COM104 [VCP0] selected module v4.01 Action: read unlock codes unlock method: read codes Model: Movistar-Match Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:5097:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: Z525.C136.HW1.SW7.V3.03_MX Version: YUANDA23C_09A_HW 86 byte(s) read imei: 355XXXXXXXXXXX connection Ok 193 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 0000 181 byte(s) read reading data... 228 byte(s) read warning: unknown lock version: E4000000 error: operation failed ! Finished, time used: 13 sec Remove/Install battery now ! |
09-05-2011, 23:11 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | please, send this operation log text and full flash backup from your phone to [email protected] |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
