Old 10-25-2005, 13:53   #1 (permalink)
Member: 50037
Sonork: 1580523
Thanks Meter: 193
c115 cannot make calls
i have an c115 hanset cannot make or receeve calls. allways shows masege "call ended call failed user busy" & sometime hange after this masege please help me to solve this problem.
B.R.
Old 10-25-2005, 14:05   #2 (permalink)
Member: 85718
Thanks Meter: 449
Have you tried other sim card from other network?
Old 10-25-2005, 14:17   #3 (permalink)
Member: 50037
Sonork: 1580523
Thanks Meter: 193
yes i tried it with other network it is working fine but both r 900 band so what is the problem?
Old 10-25-2005, 19:42   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
I think it's not bad to check phone hardware in this situation.
Old 10-26-2005, 08:07   #5 (permalink)
Member: 50037
Sonork: 1580523
Thanks Meter: 193
Originally Posted by InfinitySupport
Hi,
i also check it with 1800mhz band it is working fine. i think it is not hardware problem coz it shows full network & also shows distebence at incoming & outgoing so i think it is software problem.
B.R.
Old 10-26-2005, 08:15   #6 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
try to flash it phone will be ok full flash it
Old 10-26-2005, 08:51   #7 (permalink)
Member: 50037
Sonork: 1580523
Thanks Meter: 193
allredy flashed it but same results. any other solution to solve this problem?
B.R.
Old 10-26-2005, 12:18   #8 (permalink)
Member: 130995
I don't think it's software problem. If phone works fine at 1800 this means that phone software works w/o problems.
Old 10-27-2005, 09:46   #9 (permalink)
tersace's Avatar
Member: 44483
Thanks Meter: 4
Does it have a 1 or 2 on the front screen? I had one that was showing the nuber 2 in the corner of the screen (Line 2) if this is the case you must change it to line 1 from menu.
E700 Cannot make calls!!! HELP tittu SYSOL Platform 3 12-14-2005 13:43
NEC 338 cannot make calls felix NEC 5 06-07-2005 17:56
e616 cannot make calls 1579 NEC 5 04-10-2005 16:35
t100 full network cannot make calls SATISH VLSI, Conexant, Skyworks and Old Models 5 05-20-2004 00:27
samsung s300 CANNOT MAKE CALLS WITH FULL SIGNAL crossings Trident/AGERE Platform 10 10-18-2003 09:25
Page generated in 0.16410 seconds with 9 queries
