Old 11-25-2009, 16:06   #1 (permalink)
Member: 491115
Thanks Meter: 3
help me in pinout
i need help to find pin out of this n82y with micro usb connector
when i use pinfinder i get this message:
software version: 1.20
cable type: 1x5 (L5B)
platform: MT: MT6205, MT6217-MT6235
searching adapter at COM45...
adapter found, version: 2000
pins: 5, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
19200 fixed
19200 fixed
19200 fixed
failed to detect pins
time required: 11 sec
Trying to Power-On...
Power On !
Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries")
The Following User Says Thank You to zie_dab For This Useful Post:
Old 11-27-2009, 19:33   #2 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
pins: 5, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
19200 fixed
19200 fixed
19200 fixed
19200 fixed
Power On !
hello
check this one picture & make this rx tx.......
The Following User Says Thank You to rameez_gsm For This Useful Post:
Old 12-06-2009, 16:11   #3 (permalink)
Member: 491115
Thanks Meter: 3
Originally Posted by rameez_gsm View Post
hello
not good ......solution
Old 12-06-2009, 17:53   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
why not good? if it is not eworking- then just swap tx/rx wires with places
Old 12-07-2009, 14:21   #5 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
hello change rx tx make rx place tx & tx place rx & check it
Old 12-13-2009, 10:52   #6 (permalink)
Member: 491115
Thanks Meter: 3
not.....working
Old 12-13-2009, 13:51   #7 (permalink)
Member: 491115
Thanks Meter: 3
this is the pinout
COM45 [VCP0] selected
module v3.02
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9303:0003
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.3.02, database date: 10.12.2009):
A200_PCB01_GPRS_MT6225_S00.SW_V00_02_AOLIFENG.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info protocol ver: 04
ver. sw 1: A200_PCB01_GPRS_MT6225_S00.SW_V00_02_AOLIFENG.BIN
ver. sw 2: A200.SW.V00.02.AOLIFENG, 00000000
code offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting ffs/eeprom structure pass 1...
detect standard ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Finished, time used: 62 sec
Remove/Install battery now !
Old 02-22-2010, 11:21   #8 (permalink)
Member: 491115
Thanks Meter: 3
i need other pinout
i need pinout of n82y same like the one on this post but with touch screen
Old 03-13-2010, 03:36   #9 (permalink)
Member: 750053
Sonork: fffrfr
Thanks Meter: 56
please give me the flach file for this phone yrgent thanks dear
Old 03-13-2010, 11:54   #10 (permalink)
Member: 148515
hello guys!
if this phone is MT62xx CPU based- here is example how pinout can be found in minutes
http://forum.gsmhosting.com/vbb/5530460-post2.html
help me in pinout Kingbond-KDI-D528 jinlilai88 Infinity-Box 13 12-17-2009 14:49
6303 help me in ufc pinout melt666 Nokia Base Band 5 ( BB-5 ) 1 08-14-2009 13:04
please brothers help me in 6670 and i'm sorry to post here but please help me please Mohamed_Alsayed Nokia Digital Core Technology 4 ( DCT-4 ) 0 06-16-2008 21:57
please help me find pinout for sch-n300/150/t300 etc maxheadquarters Various CDMA/TDMA Cell Phones 1 03-24-2007 21:31
plz help me with pinouts. i did like here and a little connection is but not fully gladeo Old Ericsson Phones & Sony Phones 1 05-31-2002 22:44
Page generated in 0.21626 seconds with 10 queries
