12-13-2009, 12:54 | #1 (permalink) |
Insane Poster Join Date: Jun 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 41
Member: 153321 Status: Offline Thanks Meter: 8 | help me in pinout Kingbond-KDI-D528 software version: 1.20 cable type: 2x5 (L10C) platform: MT: MT62xx (autodetect) searching adapter at COM17... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 41 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") |
12-13-2009, 18:28 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! before searching pinout you must do 3 easy steps, please check if you followed all of them: 1. Make sure that this is mt62xx MCU based phone. tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is MT62xx. Now activate Silent mode in phone by pressing and holding "#". 2. Count number of pins in system connector. After this is done- pick correspondent cable. For example if you counted 2x6 pins- it is in total 12 so no point to put L14D cable instead of correct one, L12B. 3. Select cable type, connect power crocodiles in the place of battery. push "Power On!" in software. Now phone is powered with pinfinder power. Try to switch it On. This is main rule for success pinout search. (Phone must turn ON) if it does not turn On- no point to search for pinouts. you will not find it. Start from modifying your main infinity box to deliver more power to pinfinder. There is one diode which must be removed and shortcutted. Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done. after you get phone powered- you are ready to find phone pinout. press and Hold phone power button and start search. |
12-13-2009, 22:32 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, if you have big-type box- you must remove and shortcut this diode. it is limiting output power from 5v to 4,3. 0,7 volts is droping on that usless diode |
12-14-2009, 14:30 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! Make sure that this is mt62xx MCU based phone! you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is MT62xx. |
12-15-2009, 23:28 | #10 (permalink) |
Member: 153321 Status: Offline Thanks Meter: 8 | HELLO! Only D528 undetectable pinout, the other cell phone can be. For example: T828d V869 V868 V520 I929 I939 T728 T718 T318 can detect pinout. |
12-17-2009, 02:06 | #13 (permalink) |
Junior Member Join Date: Oct 2008
Member: 877737 Status: Offline Thanks Meter: 0 | shuld e as on all kdi.. rx 8 tx 7 rx 9 tx 8 anyway . connect ground somewhere into phone ( somewhere into metal ) and search as indepenent mode some kdi models require startup from battery.. you dont need to cut off nothing |
help me in pinout | zie_dab | Infinity-Box | 9 | 03-13-2010 11:54 |
6303 help me in ufc pinout | melt666 | Nokia Base Band 5 ( BB-5 ) | 1 | 08-14-2009 13:04 |
Anycool Kingbond KDI D528 | paulbs | Chinese Models & Cloned Phones | 3 | 06-20-2009 19:45 |
please brothers help me in 6670 and i'm sorry to post here but please help me please | Mohamed_Alsayed | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 06-16-2008 21:57 |
plz help me with pinouts. i did like here and a little connection is but not fully | gladeo | Old Ericsson Phones & Sony Phones | 1 | 05-31-2002 22:44 |
