Old 11-25-2008, 16:48   #1 (permalink)
kasra's Avatar
Member: 103435
Thanks Meter: 49
n96 one sim double slider
hi guys
n96 one sim double slider can socket is 5pin like nokia 5610 5310 anyone can help me find pinout??
Old 11-25-2008, 19:28   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
in most cases pinout is not in system connector.
i would advice to examinate handsfree port or look for test points on PCB.
i can teach how to do this by multimeter (voltage measuring)
Old 11-26-2008, 08:03   #3 (permalink)
kasra's Avatar
Member: 103435
Thanks Meter: 49
i must read the manual of find pinout with voltage measuring? or other solution?
Old 11-26-2008, 19:05   #4 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 11-26-2008, 19:46   #5 (permalink)
kasra's Avatar
Member: 103435
Thanks Meter: 49
thanx for ure help i found the pinouts and i will get a image and upload it for other guys really thanx!!
Old 11-26-2008, 21:05   #6 (permalink)
Member: 148515
hello!
we will wait your pinout picture for adding to our pinout collection.
Thank you in advance!
Old 11-27-2008, 07:45   #7 (permalink)
kasra's Avatar
Member: 103435
Thanks Meter: 49
here is the pinouttttttttttttttttttttttttt
The Following 3 Users Say Thank You to kasra For This Useful Post:
Old 11-27-2008, 19:51   #8 (permalink)
Member: 148515
hello!
thank you very much! will be inculeded to out collection
Old 12-28-2008, 14:06   #9 (permalink)
Member: 95476
Thanks Meter: 185
this another model for n96 ok rx tx in left or rigt ok
Old 12-29-2008, 01:43   #10 (permalink)
Member: 148515
hello!
thank you very much for your help!!!
Old 02-02-2009, 16:00   #11 (permalink)
aco
aco's Avatar
Member: 18927
Thanks Meter: 36
Somebody have pinout for this ver.??
Old 04-01-2009, 13:44   #12 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Did anyone find the pinout ?
Thanx !
Old 04-01-2009, 15:15   #13 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
I removed the processor but I don't know which are Rx and Tx .
Old 04-01-2009, 17:44   #14 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
And the winners are :
Old 04-01-2009, 18:52   #15 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
The Following 3 Users Say Thank You to usernome For This Useful Post:
pinout n96 new pcb dual slid one sim card omega-telecom Infinity-Box 3 10-13-2012 13:09
turk lang on n95 double slider mr_loverman Infinity-Box 1 09-22-2008 21:54
turkish language on n95 double slider mr_loverman Infinity-Box 2 09-22-2008 21:31
N95 double slider pinout here bifout Infinity-Box 11 03-28-2008 19:32
N95 DOUBLE slider hassan1975 Infinity-Box 1 01-13-2008 12:44
Page generated in 0.24483 seconds with 10 queries
