12-25-2008, 23:48 | #1 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 203445 Status: Offline Thanks Meter: 48 | Anything for this please ? module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read eeprom Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:3903:0004 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: S9.XYDL.T1.F0.U1.L8.V3.01.BIN ver. sw 2: S9.XYDL.T1.F0.U1.L8.V3.01, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00440000 Detected eeprom/ffs address is non-standard: 00440000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 81 sec Remove/Install battery now ! BR e-gsmshop |
12-26-2008, 10:16 | #3 (permalink) | |
Member: 203445 Status: Offline Thanks Meter: 48 | Quote: Eeprom files : http://rapidshare.com/files/17687289...5.B0E.bin.html Thanks for your helps e-gsmshop Last edited by e-gsmshop; 12-26-2008 at 10:23. | |
12-26-2008, 12:33 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @e-gsmshop btw, what is the problem with phone ? I can not understand the problem. You have posted only log but no any problem description. Why ? |
Anything for this Please ? | e-gsmshop | Universalbox | 2 | 11-16-2008 10:54 |
Anything for This ? | gsavv723 | MT-BOX | 1 | 10-29-2006 23:39 |
Anything for This ? | gsavv723 | Cruiser Suite | 4 | 05-11-2006 01:34 |
Dear Andro Anything for this ? | gsavv723 | MT-BOX | 1 | 04-30-2006 10:32 |
Need Key, Patch, Crack or anything for this software | imran_qasim | Bluetooth-Software | 2 | 09-17-2005 07:02 |
