GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   Help Me to Unlock TV900 (https://forum.gsmhosting.com/vbb/f296/help-me-unlock-tv900-655482/)
sulaiti 12-25-2008 15:47
Hi
I have a Phone TV900 with Phone Lock. and i try to read the User code with Chinese miracle but its not possible. i have try this phone Power button Long Press,Soft Press. also i try to do format ffs and safe format. but no luck.
And here is the Flash file inside the phone, i read it and keep it for safe.
flash[R901M31_PCB01_GPRS_MT6225_S00.M_RR9010001_M28102_V 1_0_0_0M0826.BIN]_20081225-180543.B0M
And here is the Log
COM4 [VCP0] selected
module v2.72
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3903:000B
Connecting, wait...
warning: wrong packet cs
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 99 sec
Remove/Install battery now !
Thank you.
InfinityHelp 12-25-2008 22:58
hello!
make format FFS complete
sulaiti 12-26-2008 09:31
Hi
infinityhelper,
Thank you very much. and i do it and success here is my LOG.
module v2.72
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: R901M31_PCB01_GPRS_MT6225_S00.M_RR9010001_M28102_V 1_0_0_0M0826.BIN
ver. sw 2: M.RR9010001.M28102.V1.0.0.0M0826, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 35 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Thanks again.
InfinitySupport 12-26-2008 11:56
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Page generated in 0.17132 seconds with 5 queries
