02-16-2010, 14:28 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | .::Help needed regarding chinese phone MT6228::. Code: COM6 [VCP0] selected module v3.07 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6228:8A02:8A02 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND warning: NOR flash chip is not installed NAND flash chip: S_DONE flash id[0004]: 00EC:007600A500C0 [SAMSUNG] K9K1208X0C flash size: 64Mb page/spare size: 0200/0010 pages/block: 0020 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00020000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_NAND_FLASH_BOOT bootcode current/expected: 3.2, 3.2 done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND error: last error: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Disconnect... done Finished, time used: 21 sec Remove/Install battery now ! |
02-16-2010, 19:01 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Code: probably flash chip completely erased |
Regarding Chinese Models & Cloned Phones Data cable / Charger etc. | .::Gsmdenis::. | Chinese Models & Cloned Phones | 15 | 06-14-2012 05:15 |
Need a968 chinese phone supply | jackyivan | Wanted Products | 1 | 06-12-2009 10:52 |
Help, help, help, need pinout chinese phone bt n200 | Hacker84 | Infinity-Box | 1 | 04-26-2009 17:37 |
i need this Chinese Phone Pinout... | LoveLess | Infinity-Box | 3 | 12-16-2007 14:51 |
Chinese cocktail - info about chinese phones is here! Phones data base! | GSMtricks | Chinese Cocktail | 166 | 11-06-2007 17:41 |
