03-28-2009, 13:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 47
Member: 126612 Status: Offline Thanks Meter: 8 | Help with Pin finder Adaptor Please ! I will try to be as detailed as possible in my explanation of my problem so that i may avoid any hassles in support trying to help me ... Firstly i have read the pin finder manual thoroughly .. i have also watched both videos carefully ... I have successfully registered and activated my adaptor so theres no issues there. I am using one of the very first infinity sets sold ( separate dongle with smartcard and separate uni box ) I trust there is no problem there. I have measured the output on pin1 from my unibox and it measures at 4.95v and adaptor power LED comes on so the adaptor is being powered correctly. I purchased the adaptor set from ipmart so i don't know if the cables supplied with it are correctly manufactured ( from what i could see in the user manual the wire to disconnect is not connected ! ) Software detects box correctly. I am using latest pinfinder software 1.17. From what i can see the problem comes in incorrect power to the phone. Phone is not powering .. i have correctly connected special power cable that comes in the pack to "output 2" socket on the adaptor and correctly connected one set of power leads ( 2 sets of leads come from cable ). Phone does not even blink ! in other words NO POWER from cable ! I followed these steps : 1 - open software 2 - search adaptor 3 - set "power on " at this stage according to power checks in the user manual i should be able to turn power on on the phone to check connectivity but nothing ! Phone power LED on the adaptor does not light at all ! I tried measuring out voltage on "output 2" socket on adaptor but only get a max of 0.8v coming from socket ! What is the correct voltage that should come from the socket to the power leads to power on the phone >? Which pins on the "output2" socket provide power ??? since i see that only pins1,2,3,5,8 are running in the special power cable ??? How do i check from here if adaptor is faulty >>>??? Any help from support would be greatly appreciated ... I hope i have been detailed enough in my request ... |
03-29-2009, 15:06 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, At first try to open unibox and short power line diode (see page-20 in PinFinder manual, you will see pictures there). Then try to press "Power" button in PinFinder software and try to power-on phone via PinFinder power lines (see "Selftest" chapter in PinFindr manual).a |
03-30-2009, 09:25 | #4 (permalink) |
Member: 126612 Status: Offline Thanks Meter: 8 | thank you for your response sir ... Tried your suggestion but still no difference .. exactly the same ... no response from phone or "phone power" LED on adaptor either ... Does it make a difference if i try another unibox maybe ???? How do i know for certain if adaptor is faulty or not ??? |
03-30-2009, 11:00 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Other unibox: if PinFinder adapter can be detected and you can see +5v voltage at unibox Pin-1 you have no reason to try other unibox. Ordinary problem with unibox is: too low volatge at pin-1, but if you have measured it and voltage is +5v (after short diode) you have no reason to try to us other unibox. If "Power" LED at PinFinder adapter is not ON after you have pressed "Power" button in software it may be that PinFinder adapter is faulty. You can contact to your reseller for replacement or you can try to check PinFinder output power circuit (but talk with your reseller first to avoid any problems with warranty): |
04-23-2009, 08:32 | #6 (permalink) |
Member: 126612 Status: Offline Thanks Meter: 8 | Sir i've sent you an email via your email option on the forum regarding this problem have you received it ?? Please advise as soon as possible as time for warranty is running out ! Thanks ... |
04-26-2009, 15:05 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Yes, we have got your mail with your discussion with reseller. Please, let me know what kind of technical advice we can give you ? We will be ready to give you any kind of technical advice, but any replacement etc. should be discussed with your reseller, we did not make any replacement directly. if you have problems with your reseller you can contact to our sales department: [email protected] |
04-26-2009, 19:52 | #9 (permalink) |
Member: 126612 Status: Offline Thanks Meter: 8 | Email sent. Please note i am not having problems with my reseller but i think maybe you just misunderstood my request in my email. But i have explained it better in the email i sent to sales department. Thanks for reply ... |
Cect V329 - cannot detect pin with Pin-finder | loukandr | Infinity-Box | 17 | 03-18-2009 19:58 |
Problem with Pin Finder Adapter | BouRRi_GSM | Infinity-Box | 14 | 07-18-2008 23:24 |
Help With Nokla 6300 With Pin Finder | palash_c6 | Infinity-Box | 2 | 05-06-2008 17:23 |
cect q380 can't find pin outs with pin finder | kiran | Infinity-Box | 4 | 04-09-2008 09:12 |
First in CHINA, Pin finder adaptor ,vodafone 225,226,dream box with se,etc | gsm-sources | Main Sales Section | 0 | 03-25-2008 04:39 |
