Old 12-11-2008, 12:17   #1 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
Pinout for Metom MT309
Someone has pinout for Metom MT309 flashing?
Thanks!
Old 12-11-2008, 17:05   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thanks!
Hello,
What is phone connector type ?
Old 12-12-2008, 10:06   #3 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
Originally Posted by InfinitySupport View Post
Hello,
Similar to Samsung D800
Looks like this:
Description:
http://www.wt-gsmphone.com/sdp/53132...tml#normal_img
Old 12-12-2008, 10:56   #4 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
If I have counted correctly it's 20 pin connector.
Old 12-12-2008, 21:44   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
lets start from checking what CPU it is based.
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software
Old 12-13-2008, 08:40   #6 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
When I type it, I get a message "language set: english". Still need to open it?
Old 12-13-2008, 09:07   #7 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
I have USB drivers for it and when I connect it to PC I can choose COM Port option. It says USB device MT6227, then installs USB Modem. It connects to PhoneSuite i have...
Can I connect it to Infinity like that?
Old 12-13-2008, 09:41   #8 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
Ok, I have connected it to Infinity using original USB cable and got this info:
Hardware version: MT6225, E03
Hardware version: EVEN25_HW
Software version: E307_JQ1F10.00.0_25S
Software date: 2006.06.14
Barcode: E30709020039549
imei: 3575560007xxxxx
But I can't flash it like that...
Old 12-13-2008, 20:30   #9 (permalink)
Member: 148515
hello!
yes, this phone is supported.
do you have pinfinder? if not- i can teach how to find tx/rx pins using multimeter
Old 12-14-2008, 15:06   #10 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
hello!
No, I don't have. If you could tech me it would be great. Thanks!
Old 12-15-2008, 19:59   #11 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
Old 12-16-2008, 07:51   #12 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
Great. Will do that and post the info.
Old 12-16-2008, 16:48   #13 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
Ok, so I get this:
Keyboard is up, from left to right (1.......20)
Pin no / Voltage (V)
10 / 2.79
11 / 2.73
13 / 2.76
14 / 2.82
16 / 2.73
Confused now.....
Old 12-16-2008, 20:16   #14 (permalink)
Member: 148515
hello!
i would try pins 13,14
try them in both way 13 as Tx, 14 as Rx and if will not work- otherwise 13 as Rx, 14 as Tx
Old 12-17-2008, 18:43   #15 (permalink)
g-zona's Avatar
Member: 80391
Sonork: 100.1601620
Thanks Meter: 66
Ok I will try that and post the results.
WBR!
Pinouts for Wi-Fi Mobile C5000 Stoyan Infinity-Box 3 04-01-2010 06:06
Connectivity for Metom m10 deffa Chinese Models & Cloned Phones 2 05-21-2009 08:59
What is pinout for metom mt309? ferhattas Chinese Models & Cloned Phones 0 09-08-2008 17:10
Pinout for N95 RM-17 like origin pinout needed ..::alexis::.. Infinity-Box 7 05-09-2008 17:54
CAN SMB SHARE WITH ME PINOUT FOR MOTOROLAS (all what u have) plss, need for emmi igor_m Wanted Products 0 09-21-2000 21:29
Page generated in 0.26185 seconds with 9 queries
