11-21-2008, 03:10 | #1 (permalink) |
Major Poster Join Date: Dec 2007
Member: 658225 Status: Offline Thanks Meter: 4 | help problem after flash alcatel c701a movistar mexico Please Help I've tried to unlock Alcatel c701 but now I still do not understand the procedure but instrcciones power begins to tighten on and shuts down to 4 seconds please help. you load the next flash, and now no lights were turned off at 4 seconds of ignition start. C701A-2ACECO1_XC19GP21_JRD26_06A_PCB01_GPRS_MT6226_S02.M AUI_06A_W06_52_SP1_V24_2007-10-27_En_Fr_Es_Pt-BR_It_simfree.B0M that file first and load it gave me error then you load the file movistar mexico C701A-5ATLMX3_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W 06_52_SP1_V24_2007-08-10_CC19ND23_En_Fr_Es_Pt-BR_It_Movistar-Mexico.B0M and the same mistake as I turn and the phone starts and 4 seconds and shuts down several times and I try the same thing please help thanks best regards @ramscell |
11-21-2008, 11:23 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. use latest version of MModule software, it's important ! 2. try to make "format ffs". |
11-21-2008, 20:09 | #3 (permalink) |
Member: 658225 Status: Offline Thanks Meter: 4 | thanks infinity box ....flash and unlock c701a ok COM46 [VCP0] selected module v2.43 Device: Alcatel-OT-C701X, C701A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A03:8A02]... CPU: MT6226 chip: 0031:8D3F:A000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.4E1E0 C93.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_A8DA411C].rpl identification#1 detection finished device-id: 4E1E0C93 identification#1 protocol ver: 05 ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN ver. sw 2: MAUI.06A.W06.52.SP1.V24, E3BE2557 ffs offset/size: 01200000/00E00000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 01107300908464 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_4E1E0C93_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24.BIN_A8DA411C_20081121-122602.B0X.bin Area: Firmware flash: 01227E22302200:2BEA0000000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CC19GP21 done flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................counter: 01 done flash: 01227E22302200:2BEA0000000000 flash: 01227E22302200:2BEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... formatting... flash: 01227E22302200:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_4E1E0C93_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24.BIN_A8DA411C_20081121-130108.B0X.bin Finished, time used: 2152 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to ramscell For This Useful Post: |
alcatel 303x problem after flash | Akvarius_Sistem | Infinity-Box | 17 | 12-11-2009 20:12 |
Problem after flash alcatel 203a [ANSWERED] | hmontoya | PolarBox 3 | 1 | 11-17-2009 19:05 |
5310 problem after flash.Please help for this problem. | caremobiles | Nokia Base Band 5 ( BB-5 ) | 9 | 04-30-2009 15:39 |
Help! 3390 network problem after flashing | djdams | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 08-12-2005 01:43 |
Z1010 Network Problem After Flash Please Help Need Solition ! | yildirim | Cruiser Suite | 1 | 07-11-2005 08:15 |
