Help Product supporter I falsh bleu 151x ok set for unlocking.I download flash file from support site & flash it.After store backup Flashing fail & set dead . I used Pinfinder. Plz hepl me soon Log hear................. |
This time log can not uploadingm .after some time i will do |
You must charge phone battery due to it lokks like battery is empty. |
I flashed with full charge battery & 7310 cable bul not succes...........Plz help Log here COM6 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: C:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080601-173923.70E.bin Check space Ok Write... Area: Firmware flash: BF7353FFFF0052:00008500000000 Write: Firmware error: no any expected answer error: flash write error: 02000000:00002000 error: wrong answer: C5 error: flash write error: 02000000:00002000 error: wrong answer: C5 error: flash write error: 02000000:00002000 error: wrong answer: C5 error: flash write error: 02000000:00002000 --------------------------------------------------------------- I think bin file problem ................ Plz help |
You mjst download latest software from support area and try again. But I don't see any reason to flash this phone. |
I am useing Latest software 2.12a version Any other idea |
It is my First log when set becone dead COM6 [VCP1] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: C:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080601-123659.70E.bin Check space Ok Write... Area: Firmware flash: BF7353FFFF0052:00008500000000 Write: Firmware error: no any expected answer error: flash write error: 02000000:00002000 Write failed Finished, remove/install battery now ! Time used: 70 sec |
What is PModule02 version ? |
Thanks for reply version pmodule02 is 1.13 |
If anybody flash bleu 151x succesfully then post result & log .Thanks |
@ 42 Can i Make old position my bleu 151x..............I have backup file......................If yes then plz post step.........thanks |
Hello Infinity team My problem is still .Plz help |
Plz infinity team sir, check ur bleu 151 bin file posted on support site & reply me.solp my problem. Thanks |
contect on my ym [email protected] doller |
