IMEI_info | 06-04-2021 16:41 | No, still no fixed I got all time same without select preloader Quote:
Operation : HW Report [ v2.24 ]
HWreport : Mode : UFS
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM4)
MODE : BOOTROM
PORT : 4
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Cervino
TYPE : MODERN RAPHAEL
BROM : MEID : 0A506E73F820E140ED5E55171E976143
BROM : SecLevel : 0x000000E7
BROM : SecMode : SBC+SLA+SDA+EXT
BROM : BROM|BL : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v2112 | Manual : Disabled
BROM : SOCID : 5FB7FA1B1A6288AB2C50E7B0FD888B80F6185220DD23584718 3CF11AC197E816
BROM : SLA : Local Auth
BROM : SLA : Auth Started!
BROM : SLA : Auth Passed!
BROM : SLA : 0x0000001F
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
DA : EMI : Failed to get EMI info from selected source!
Boot done!
Memory Info :
CID : 150100424A54443452092C2247188781
MEM : VEN : SAMSUNG | OEM : 01 | DEV : BJTD4R
DAT : Size: 29820 MB, Max.Speed: 52000 kHz, blklen(512), nblks(61071360), ro(0)
EXT_CSD Info :
EXT_CSD rev. : v1.8 ( MMC v5.1 )
CSD struct rev. : v1.2
Supported command sets : 1h
HPI features : 1h
BG operations support : 1h
BG operations status : 0h
Correct prg. sectors : 0h
1st init time after part. : 3000 ms
Min. write perf.(DDR,52MH,8b): 0h
Min. read perf. (DDR,52MH,8b): 0h
TRIM timeout: 0 ms
Secure feature support: 55h
Secure erase timeout : 8100 ms
Secure trim timeout : 5100 ms
Access size : 3584 bytes
HC erase unit size : 512 kbytes
HC erase timeout : 300 ms
HC write prot grp size: 8192 kbytes
HC erase grp def. : 0h
Reliable write sect count: 1h
Sleep current (VCC) : 7h
Sleep current (VCCQ): 7h
Sleep/awake timeout : 26214400 ns
Sector count : 3a3e000h
Min. WR Perf. (52MH,8b): 0h
Min. Read Perf.(52MH,8b): 0h
Min. WR Perf. (26MH,8b,52MH,4b): 0h
Min. Read Perf.(26MH,8b,52MH,4b): 0h
Min. WR Perf. (26MH,4b): 0h
Min. Read Perf.(26MH,4b): 0h
Power class: 0
Power class(DDR,52MH,3.6V): 0h
Power class(DDR,52MH,1.9V): 0h
Power class(26MH,3.6V) : 0h
Power class(52MH,3.6V) : 0h
Power class(26MH,1.9V) : 0h
Power class(52MH,1.9V) : 0h
Part. switch timing : 2h
Out-of-INTR busy timing: ah
Card type : 57h
Command set : 0h
Command set rev.: 0h
HS timing : 0h
Bus width : 0h
Erase memory content : 0h
Partition config : 48h
Boot partition size : 4096 kbytes
Boot information : 7h
Boot config protection: 0h
Boot bus width : 2h
Boot area write prot : 0h
User area write prot : 0h
FW configuration : 0h
RPMB size : 4096 kbytes
Write rel. setting : 1fh
Write rel. parameter: 14h
Start background ops : 0h
Enable background ops: 2h
H/W reset function : 1h
HPI management : 0h
Max. enhanced area size : 747h (15261696 kbytes)
Part. support : 7h
Part. attribute: 0h
Part. setting : 0h
General purpose 1 size : 0h (0 kbytes)
General purpose 2 size : 0h (0 kbytes)
General purpose 3 size : 0h (0 kbytes)
General purpose 4 size : 0h (0 kbytes)
Enh. user area size : 0h (0 kbytes)
Enh. user area start: 0h
Bad block mgmt mode: 0h
Overall status :
MLC status : 0% - 10% used
SLC status : 0% - 10% used
EOL status : Normal ( Less than 80% reserved blocks used )
Done!
Elapsed: 00:00:17
Operation : Identify [ v2.24 ]
Mode : FLASH
MODE : BOOTROM
PORT : 4
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
Boot done!
Done!
Elapsed: 00:00:23
Reconnect Power/Cable!
Mode : FLASH
MODE : BOOTROM
PORT : 4
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
Boot done!
Done!
Elapsed: 00:00:26
Mode : FLASH
MODE : BOOTROM
PORT : 4
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
Boot done!
Done!
Elapsed: 00:00:19
Mode : FLASH
MODE : BOOTROM
PORT : 4
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
Boot done!
Done!
Elapsed: 00:00:28
Mode : FLASH
MODE : BOOTROM
PORT : 4
BROM : Init BROM
BROM init passed!
CODE : Cervino
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
Boot done!
Done!
Elapsed: 00:00:23
